65 f100 loose shifter
darn near impossible for me to put this 65 f100 in to gear much less find neutral because it seems the shifter is loose. before i bought it i went for a test ride with the guy and it ran great except he was really jerkin the shifter around to switch gears. this is my first stick shift vehicle and i need to fix this before i can drive it.
background- the shifter was relocated from the steering column to the floor. i also need to relocate the gas tank from behind the seat considering im very tall and need more leg space. any ideas or help would be appreciated |
Relocating the tank will net you 0.00" in legroom.
Buy a new shifter. The one you have cant be rebuilt unless you know just exactly what it is. If it is that sloppy it has been bent folded spindled and generally mutilated. Most aftermarket three speeds are junk when new let alone when clapped out for abuse. Garbz |
Originally Posted by garbz2
(Post 13091009)
