For the most part you get what you pay for on these bars. Good bars last a long time and are super bright.
You have things you need to look at like are you looking for more of a spot, or flood of light. Some are better at one than the other. M&R and Rigid makes good units. I think KC is making LED units now, but not sure if they are light bars.
Good LED light bars are expensive, some can take a .22 bullet without any consequences, and thats what I'd want if it was going on the bumper area.
And yes, they all aim the light differently, some spread the light, others focus it like a beam in one spot, etc. So make sure you know what you're buying. Sometimes you can get lucky with cheap stuff though too, sometimes ... I bought some 10 watt LED lights, and they were 20$ each or something, and they're going on 3 years I think. They had a solid aluminum housing, and glass lens. I'm cheap though, and not planning on spending hundreds of dollars on a light. |
The Rigid lights are good quality and super bright. The only thing you are sacrificing by mounting them behind the grille is the height. The higher they are the better they illuminate the ground. So the higher you mount a light on a truck the better you will see things.
I use the rigid lights on my f150. I just have the duallys from them and they work great. Well worth the money in my opinion.
I hear nothing but great things about the LEDs (besides price). Wish I had the extra cash
Step-Son has the rigid 20" and double running lights... they light up the road even in the daytime !!!!!!!!!!
but they should for what they cost - he only rarely uses them as they are TOO bright for running around the dfw area :) |
I'm running a 50" rigid mounted on top of the truck with rigid brackets. It is a straight spot light and lights up everything for right at a 1,000 yards. Wouldn't have anything else ever.
