Gemmer steering box ID help
I think its from a big truck, 5DC62 is cast in below the GEMMER. Any help would be appreciated. The mounting flange is bigger than our 57 F100.
Any chance of a picture?
A larger size unit was used on the bigger trucks. However, the last pic of the end plate with the adjustment screw and lock nut looks a little different than I expected. I have the larger Gemmer unit in my F100. Took a few modifications but worth the extra mechanical advantage you gain. I can't give any help with the casting numbers and doubt if you will ever unlock their mystery!
Originally Posted by spurredon
(Post 13054471)
Originally Posted by CB_Cyclone
(Post 13054545)
I would like to put this in a 57 F100, how did you do it? Trim the casting, open up frame area? Thanks
I finally found it in this book. that gearbox is out of a late model 1963 F350 part number C3TZ 3504-W
1 Attachment(s)
(Post 13051401)
1963/66 F350 model 84 Chassis & Cowl Open Drive-Away (no windshield, no cab). Model 84 steering gear housing, steering shaft and worm are different than F100/350 model 81 conventional cab. C3TZ-3524-N shaft & worm F100/350 81 conventional cab: 40 7/16" long / C3TZ-3524-R shaft & worm F350 model 84: 45 7/16" long. |
