94-97 F250 F350 7.3 Powerstroke Engine and Truck parts parts
All prices are OBO, would really like to make someone a great "package deal" rather than shipping all this stuff a part at a time. Feel free to call or text 817-602-5267.
94-97 F350/F250 7.3 Powerstroke and Truck Parts List: SCT DashScan $30 Gas Pedal Assembly $75 1996 F350 Automatic Engine Computer F6TF-12A650-AYE EEC-V DPC202 W4 $125 3 IPRs $100 IPC $40 Oil temp Sensor $10 Oil pressure sensor $10 Water temp sensor $10 Air intake temp sensor $10 Boost pressure sensor $20 Vacuum sensor, manifold and reservoir $20 Brake Pressure sensor and peddle light switch $10 Starter Relay $10 Glow plug Relay and 3 Glow plugs $30 Fuel Tank Valve and Switch and fuel lift pump piston $10 HPOP (core) with Gasket, Gear, lines, new O-ring kit, and Tank top $100 1 under valve cover injector harness, 8 injector oil “hats” $20 Alternator $40 New out of box water pump $60 Valve cover breather assembly $10 Oil Cooler Assembly has a small O-ring leak but no rust in good shape $75 Bell Housing Spacer $20 Dual Mass Flywheel $75 Headlight Switch $10 Glove box latch and light $10 Under hood light $5 Blinker Switch $25 Engine Lift Rings and misc. brackets $10 Tailgate Handle and latch hardware with link rods $30 Emergency brake pedal assembly $15 Dash AC vent assembly (1) $5 Dome Light Assembly Older model one but nice $10 2 wiper blade arms $10 Rear drum brake hardware spring parts kit $10 Factor Stereo Amplifier F4TF-18B049-AC $30 Windshield Wiper Control VF3TF-17D539-CA $20 Seat belt Chime VF2TB- 10D840-AA $10 ABS Control Module (dually only) F3FT-2C018-BB $20 Anti-Theft Module and 1 key fob remote $10 |
Anti theft module, what year? Interested in wipers, under hood light-do you have the harness for it as well and do you have any seat belts in gray 94-97 F series reg cab?
thanks |
What's your package price, no flywheel included? Quite a few other little things I wouldn't need, but I don't want to list them all. I really don't need much from the flywheel down. PM me if you want. Interested in the pcm for sure.
Can I assume that blinker switch means the turn signal lever. If so I'd like it buy it.
anti theft is from a 1995 F350, I do not have any wiring harnesses or seat belts
The Blinker switch is the multi swtich from the steering column. There are two guy in front of you the are considering a package deal price for it all, if they pass i will contact you for purchasing these parts if that ok?? |
Text sent as instructed...
Whoda- Thats fine let me know what you end up doing.
all part are sold, in a package deal. Thanks for looking!
Thanks for the update, the search continues!
