78 f250 part out
parting out a 1978 f250 standard cab 4x4
400m motor with holley street avenger intake and edelbrock performer carb headers complete engine np435 4speed transmission z-bar and clutch/brake pedal np205 transfer case front and rear driveshafts dana 44 high pinion open knuckle front axle 4.10 gears complete dana 60 4.10 gear limited slip rear axle complete leaf springs with mounts complete still on axles can be sold seperate complete power steering setup pump, mounts,hoses, steering box, cooler lines, the whole works still together set of matching rims 2 front 16" steelies and 2 rear duallys that fit standard axle inner is flat outer looks like a dually 6 rims total dash blue some weathering steering column for floor shift 8 track player steel flat bed with headache rack wood floor heavy rear bumper decent driver fender pass is rusty but wheel arch is good decent hood with letters all glass is good doors are ok trim on cab is ok core support is good inner fenders are good wiring looks ok if there is any interest i can get pictures for items you want, i can ship small stuff would rather you pick up big stuff unless you are experienced with shipping it. probably more stuff i am missing just ask. thanks, tim http://i189.photobucket.com/albums/z...pahman/092.jpg |
Is it a saginaw power steering? If so, im interested.
how do you tell what type it is?
take a picture of it. I doubt it will.Probably is a c2 pump.
Yes, that's not a saginaw pump.
interested in the front & rear axle...what's the wheel bolt pattern?
i believe it is 8 on 6 1/2 pretty much the same from the 70's through 98
got the glass out looks to be in perfect shape factory tint
dash is in real nice shape blue in color, pad is a little rough not horrible but... http://i189.photobucket.com/albums/z...ps5a003089.jpg also have 4 245-75-16.5 michelin atx tires on american racing rims 8 lug good tread left rims will clean up nice http://i189.photobucket.com/albums/z...ps2a803d62.jpg http://i189.photobucket.com/albums/z...ps93aa8bbf.jpg also have the metal trim that goes around the headliner white in color nice shape and white sunvisors http://i189.photobucket.com/albums/z...ps65110320.jpg |
brush guard is sold
cab lights are sold seats are sold truck has a clear title if someone wanted the door and frame |
thx Ian - appreciate the quick reply
I have an lifted 81 F150 that I'm wanting to put 4.10 gears in. Have Dana 44 IFS front & Ford 9" rear w/ 3.25 gears. Just bought M/T 5 x 5.5 wheels & 35" tires and don't really want to invest in new wheels if I don't have to. Still debating it tho. Still doing research to see if I can put 4.10s in what I have. I'll let you know. V/r - John |
Could you tell me if the truck had power brakes? I am looking for the brake pedal, booster bracket and brake lines from the MC to the proportioning valve. Thanks
Are you willing to sell the intake and carb separate?
How much for the rear driveshaft and the z bar for the clutch?
flatbed
Do you still have the flatbed?If so how much do you want for it?
Thanks Steve |
