73-79 Dentside parts f/sale
1973-79 dentside parts for sale...
Black dashpad Jade green door panels..non XLT but with aluminum trim on upper area Jade green finger tip cup Jade green armrest pad, LH tailgate finish panel (Ford lettered center panel) tailgate finish panel, upper w/handle surround trim Tailgate hardware...side straps, hinges, latches, fasteners Super Camper Special nameplates upper bodyside moldings with rub strip LH Longbed, Door, SuperCab rear Fender(LH)..need to dbl check for RH mldg RaceTrak mldgs: L fender, 1 of 2 toolbox door, SuperCab(LH), bed front RH(with toolbox) Toolbox door latch w/key Lighted visors..Tan, Red and Black..LH tan is w/o its rod Sport steering wheel and horn button..will not seperate Dash Bezel, with a/c and woodgrain RH dash end trim..metal type..woodgrain and black inset finish available Ranger XLT glovebox nameplate Various fender/cowlside name plates..inquire with need Grille inserts..73-77...let me know what year and which side as I have both versions, but opposite sides so no match pair headlight doors..78-79, argent finish Tilt/cruise column..out of a 78 E100.. cruise control horn pad..78-up - cs65 |
What do you want for the dash bezel?
Happen to have a 73-79 ac/ heather blower box?(engine side) |
How much for the door panels....I could have them painted.
what shape is the dash pad in? if in good shape how much shipped to 89032.
Thanks Tim |
79 Silversreak et al, post your contact info in my profiles visitor msg section or PM me with the contact info and I will reply to you each with pertinent info regarding your parts requests.
Additionally, I also had the bedside cleats used for tieing loads down. - cs65 |
Will the sport steering wheel fit a 73? If so, how much shipped to 02857? Thanks!
how much for the column, shipped to 15401?
prices per forum rules?
I'm interested in the sport wheel if you could pm me or send me an e-mail directly to jpicard1989@myfairpoint.net
Thanks, BFT302 |
Sport wheel, jade green door panels and lighted visors are all gone...as is the dash pad
I have RH dash surround trim in woodgrain or black(potmetal ones) 4WD transfer case boot and trim ring, NP 435 shift knob, transfer case shift knob I also have some race track trim as well as upper mldgs w/rub strip for SuperCab & regular cab. Emblems... Bedside XLT, truck model plates for most...even a 78-9 Bronco Ranger. No engine parts or drivetrain at all for 73-9 - cs65 |
Hi, I am looking for rh lower front fender racetrack trim. Do you have that? How much shipped to 95249?
Thanks, Matt |
Im not sure about the RH... I will look in the garage tonight or tomorrow.
- cs65 |
