Ford Truck Enthusiasts Forums
-   1961 - 1966 F-100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum40/)
-   -   Help with horn issues (http://www.ford-trucks.com/forums/1226031-help-with-horn-issues.html)
unibody madness 02-25-2013 09:29 AM
The 1961-62 f100/250 2wd with floor mounted shifter, has a different turn signal/horn arrangment, than I have found on the three speed column shift set up.
The horn grounding wire (actuator), pictured below is missing in my application.
Thanks to Number Dummy, as well as others, I now know what I am looking for.
The books show the following wire to be part of the turn switch, it is not, but may have originally come with the switch
horn wire
http://i536.photobucket.com/albums/f...s/IM002015.jpg
T/S switch installed
http://i536.photobucket.com/albums/f...s/IM002016.jpg
horn wire and contact installed
http://i536.photobucket.com/albums/f...s/IM002017.jpg
The turn signal switch (CODZ-13341-A), and The steel turn signal mounting plate (CODF-13304-A) that goes above them,was bought several years ago from Green sales but did not come with the wire.
Thanks to Bill (ND), I now know there is no seperate part number for this piece
If anyone has one, or knows where I can locate one, please let me know. I am in need of two (2)
Thanks
John
