ford 5.4 dpfe sensor question
I picked up a 98 f-150 with the 5.4 and the wire harness going to the dpfe sensor has been cut,so the plug is in sensor but the wires are too short to re-attach. Can you get just the end of the harness to splice in so I can hook up the wire harness to the DPFE sensor?
Thanks |
You might try someone like Napa. they may have something. If not, hit your local salvage yard and cut one off then splice it to your harness. Most Fords from the late 90's -up usually use the same plug.
Ok I was able to re-wire it, and as soon as i fired it up I could tell a difference in the way the truck ran.
The cel is still on and after the truck warms up and I drive 15-20 miles it starts to run really weird/ruff, i get up to about 50mph and the truck starts to shake, but as soon as i get down below that it stops. It only does this after the truck has been running and warmed up. When I am driving it cold it runs perfect, and even when this issue happens,if I hit the gas it takes off like a rocket and no stumble/running ruff, but as soon as I drop back down to normal driving it starts doing it again around the 50mph mark:-huh |
I am trying to figure out the logic of cutting off the DPFE sensor wires...
Thanks! |
Originally Posted by jerem0621
(Post 12858734)
Thanks! |
ok I took it in to get scanned and it said that the dfps was not getting a ground, so I repaired the wiring and while I was at it gave it a sea foam treatment.
Well it seems to be running better, and it has lots of power but the CEL is still on and at one point it was flashing until I slowed down to turn around and then it want back to a solid light Any ideas? |
The little hoses going to the DPFE sensor. Did you make sure that they are clear of obstructions?
(Post 12883658)
Straighten out a coat hanger and simply run it through the hoses. Be careful not to puncture the hose.
I would simply wipe the hoses off with a damp rag. You could probably get replacements for a few bucks at the parts store. But I would try to make sure they are clear before I did that. The sensor may be bad but let's do the free stuff first. |
