Ford Truck Enthusiasts Forums
-   1973 - 1979 F-100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum38/)
-   -   using double overdrives with a cummins (http://www.ford-trucks.com/forums/1220059-using-double-overdrives-with-a-cummins.html)
F350moneypit 01-29-2013 02:25 PM
I have been reading a lot of threads about cummins conversion and the subsequent gear changes people are doing to get the rpms down.
Has any one tried this combo:
cummins ->o/d tranny ->transfer case->gear vendors over drive unit?
as long as your not in four wheel drive with the O/D activated it seems like that could drop the rpms quite a bit.
co425 01-29-2013 03:59 PM
Look at the specs of a gear vendor. I don't think it will live long with even stock cummins torque. A mild cummins can easily pump out 600 foot lbs. I think your are better off with a rear end ratio change with the nv4500 5 speed or nv5600 6 speed. Both tranny's are the same overdrive ratio.
lurch460 01-29-2013 05:29 PM
I dunno bout that,I have seen some gearvenders go through hell on the dragstrip. I know there used to be two versions,one for higher hp and torque. I was at the SEMA show about 7 years ago and talked with gear vendors and I do recall them saying they had one available for diesels that made some serious power, but things might have changed since then. This is my plan if I ever get around to putting a cummins in.
1972RedNeck 01-29-2013 06:04 PM
If I had the money I would love to have 4.10's, a Getrag and a GearVendors in my Dodge. That would put the overall ratio at 2.33:1. Rigth now I have the 'rag and 3.07's, which puts me at 2.38:1.
F350moneypit 01-29-2013 07:41 PM
If I remember right most gear vendors units can handle 1500 hp but I don't know what torque values they're rated at.
co425 01-29-2013 08:05 PM
I could be wrong but I seem to remember it only being around 400 ish ft lbs. The hp numbers were there just not the torque. Unless they now make a diesel unit.
Higbean 01-29-2013 09:18 PM
It seems to me every time I talk to a guy with a Gearvendor, they are bitching about blowing em up. They seem like a good idea, but for the price of one, you'd be close to putting in an Alison or a built 47RH. Heck, you could find a 6 speed 48RE with the two OD's for dang near the same price I bet.
1972RedNeck 01-29-2013 09:41 PM
Quote:
Your still not getting the RPM's down.
