Vin info on 1967 F100
Hi Bill
Need your expertise as you are the Vin Master!! :) Vin # F10YRB2940 131 M F100 D81 G 17 05000 172 4000 75 tHX sAL |
F10.. F100 2WD
Y.. 352FE V8 R.. San Jose CA assembly plant.. actually in Milpitas, CA... it is now a shopping mall. B2940.. this is missing a digit You can decode the rest of your plate here: Decoding Your 1967 Ford Truck VIN - FORDification.com You're welcome....... in advance. |
Originally Posted by texinc66
(Post 12754257)
VIN: F10YRB29400 / W.B. 131 / COLOR: M / MODEL: F100 / BODY: D81 / TRANS: G / AXLE: 17 / GVW: 05000 / CERT NET HP: 172 / RPM: 4000 / DSO: 75 F10 = F100 2WD Y = 352 2V R = San Jose CA Assembly Plant. B29400 = 1967, assembled May 1967. 131" Wheelbase. M = Wimbledon White. F100 2WD, 5,000 lbs. GVWR D81: D = Medium Beige Petticrush Vinyl & Medium Beige Leeds Pattern Woven Plastic / 81 = 81B Custom Cab. G = MX Cruise-O-Matic. 17 = Ford 9" Rear Axle / 3.25-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity. 5,000 lbs. Gross Vehicle Weight Rating. 172 net HP @ 4,000 RPM 75 = Phoenix AZ Ford District Sales Office, where the original selling dealer ordered the truck from. R assembly plant code was originally assigned to the Richmond CA plant. New San Jose plant replaced it in 1956, as Richmond was deemed too small. Irony: The Richmond plant is there today, recently restored and rented out for mixed usage. Huell Howser's PBS TV show "California's Gold" did a segment on it. |
