turbo upgrade
dos any one know what to upgrade my turbo to if i got banks six gun tuner with dpf out and banks air filter
Originally Posted by davidherman89
(Post 12741951)
Well would you know what would make my truck over boost when I'm only giving 25% of gas
(Post 12742267)
It could be that the high pressure turbo has an issue or your VGT is having an issue. It is not the banks. |
Well its not throwing any codes
If you have the IQ and check for codes and there are none...then how often are you regening?
Has your mpgs dropped quite a bit? |
No mpgs are the same and ok thanks man ill try these out
My high pressure turbo about a year ago was pushing out a little higher then I thought it should. I took it in and it was out of spec by 3.6 psi.
I had no codes either. Ford replaced it under warranty. |
Oh ok thanks man thats what I was think maybe just buy a high pressure turbo to
if you are still less then 5 year/100K then it would be a warranty repair.
Ok thanks man
That may be the weirdest thread I have ever read. Just saying
I did it last week did't work.i wouldn't recommend to anybody.
Ok so I did all that and I didn't get no code now when I'm not towing to don't over boost now when I get on it
