Rear Disc Brakes on a 1991
What would be my best options for putting rear disc brakes on my 1991 F-250 Custom 2WD using Ford parts? I have seen that the F Super Dutys have rear disc brakes but i'm not sure if the brake hardware will interchange with my drum brake hardware on my 10.25" Sterling axle housing. Would it be easier and cheaper to swap out the whole rear axle assembly and if so what model and year of truck would be the best donor? F-350 or E-350 maybe? I want parking brakes that also work like normal ( at the Caliper ) without having to go to a Driveline brake. Thanks ahead of time for any information.:)
Is the conversion for towing and hauling?
the F-superduty used 10 lug bolt pattern, and the newer superdutys use a metric bolt patern
i would look into a 99 to 05 van rear brake setup. they still used the old 8X6.5 bolt pattern, but had disc brakes. |
Originally Posted by khadma
(Post 12724051)
Originally Posted by tjc transport
(Post 12724202)
Did the van ever use a sterling axle? I thought they were Dana axles, but I might not remember that right.
Originally Posted by EPNCSU2006
(Post 12734815)
Some helpful links for converting your existing Sterling 10.25 ti disc:
1989 Ford F-250 Disc Brake Installation - Four Wheeler Magazine Ford Rear Disc Brake Kits for 9", Dana 60, Dana 70 and Sterling Ford Sterling Disc Brake Bracket 84-94 - RuffStuff Specialties |
Since the subject heading is universal enough to "1991", I don't mind taking this a bit off-track... What about converting to discs on a F-150 of the same era vehicle? Is there an easy bolt-on solution that retains the stock 5 lug pattern?
Originally Posted by rla2005
(Post 12735963)
so if you go with ruff stuff's brackets, u eliminate the backing plate, bolt in brackets, and use 96 van rotors ?
dpd, theres conversion kits for 8.8's an 9" rears all over the net
Originally Posted by 88dually
(Post 12739527)
sooo, for $50 brackets, 2 rotors from a van, and eldorado calipers w/e-brake, my dually can have 4 wheel drilled an slotted rotors, without changing rears to '99 -05 ? I'm in
That is what the manufacturer claims.
