Diagram of front suspension
I have a 51 ford f1.
Does anyone have a diagram of how the front suspension is put together? The reason I ask is because my parts are froze together, caked with grease, mud, and rust, and I want to make sure I am not missing any parts when I put this thing back together. Thanks for your help! -Aaron |
2 Attachment(s)
This what you need?
ALB,
Thanks for the pics. Appreciate it. I am more interested in picture 1. Right now my questions are surrounding the spindle/tie rod ends/king pins although trying to get off the backing plate is a PAIN and I have not succeeded in removing those 4 nuts yet. :) On a different note, is there anyway you can blow that picture up more? One last question for you because I don't see it on here. When I took the hub assembly off of the spindle, I noticed that the spindle (like any other car I've worked on) has a groove running down the middle. When I pulled it off, I did not notice a small bar of steel in that groove. Is there supposed to be one on this truck? |
1 Attachment(s)
This image should come out much larger after you click on the enlarge bar on the top of the pic., I hope it is the right one for your truck.
I suspect the groove you're talking about is the one for the lock washer that goes between the outer bearing and the retaining nut.
If you haven't don so already, order a catalog from Classic Haulers and LMC (they are free). They have good reference diagrams of many of the systems.
Originally Posted by dmack91
(Post 12724176)
thanks guys for all of your help!!
BOB, as stupid as this may sound, i never thought of buying a shop manual :-X19 |
Along with the shop manual get the Master Parts Catalog: 1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
The drawings that Ross posted are from it. |
