quick heat control question.
does anyone know the name of the in dash combination valve for the heat ac control? its behind the panel. i know what it is, just not what its called. the stupid thing has like a couple electric plugs and like 40 vac line nipples.:-huh
Originally Posted by l8ntpianist22
(Post 12687181)
Does anyone know the name of the in dash combination valve for the heat A/C control? :-X22
It's bolted to the backside of the A/C/Heater control panel and includes the "kicker" switch for the compressor. I know what it is, just not what it's called. The stupid thing has a couple electric plugs and 9 or 11 vac line nipples. When you slide the lever on the panel, the little charmer opens one damper door, closes another. Is a Bosendorfer Concert Grand the same as a Baldwin Parlor Grand? No! / 1976: There are two different types of these puppies. D5OZ-19B888-C .. A/C Vacuum Control Selector Valve Assy (Motorcraft YH-281) / Obsolete ~ 7 available NOS 1975/76 Torino/Ranchero/Thunderbird/Cougar with manual integral A/C / 1975/78 Mustang II with integral A/C / 1975/80 Granada/Monarch with manual integral A/C / 1978/80 Pinto/Bobcat with integral A/C. ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- D5OZ-19B888-D .. A/C Vacuum Control Selector Valve Assy ~ Use with A.T.C. ~ Automatic Temperature Control (Motorcraft YH-82) / Obsolete ~ 22 available NOS 1975 Torino/Ranchero from production date 2/75 / 1976 Torino/Ranchero. Pick the one you need and I'll list the sources/phone numbers. |
