97expygirl |
01-05-2013 11:57 AM |
97 ford expedition turns over idles rough then dies.
I have a 97 ford expedition the 5.4L 4wd. Recently it felt like it was sputtering especially when taking off from a stop sign it would take a minute to get up to speed and shake a little bit. The problem seemed to get worse and the check engine light never came on. the other day I was driving it and it was shaking worse and felt like it had no power the check engine light came on and was flashing. I was about 15 miles away from home and had to drive it home. I went slow and the check engine light stopped flashing for 5 miles and came on again. I got it home and parked it. My SO was convinced it needed a tune up so we got all the spark plugs and boots and had them replaced. When we went to start the truck it would turn over and then die unless you kept your foot on the gas. So far we have checked all the hoses those are fine we checked all the spark plugs making sure they were in right. we have checked 4 of the COPS im not sure which ones im assuming the ones that are easiest to check. Ive been reading on here that people with the same issue have had COPs out or their wires out? does this sound like the issue. I talked to the guy at autozone and he for one scared me by saying that the flashing check engine light meant internal damage to the motor and said that if it was a coil pack the truck wouldn't turn over at all and would not idle for even a few seconds? Idk if this is true? The guy at autozone said to buy some air flow sensor? so I did but Im convinced its the coil pack so before I put the new sensor in and have it non returnable id like to have a few ideas or someone who can back up what im saying with a solution. thanks so much to who ever replies this is my only vehicle and I cant just write it off as not working I need my truck back! Ive owned it for 2 yrs and have never had an issue. I forgot to mention it has 187k miles on it.. idk if that makes a difference. oh weve also cleaned the throttle body sensor? changed the fuel filter and lucas fuel injector cleaner though it. Thanks for your help.
