Location of TOT Sensor
I googled quite a bit and found discussions on this board and others related to the TOT sensor but none described the location of the sensor and connection. Other posts indicated that pulling the 636 KOEO code probably indicates a bad connection and not necessarily a bad connection. Can anyone describe roughly where on the transmission this is located? Getting some rather firm shifting and this is the only code related to the tranny.
What year truck etc.
It's built into the solenoid pack on the transmission.
But yeah, we need more information on the vehicle. |
Sorry, it's a 95 F150, 5.8 and E40D
The Transmission Oil Temperature (TOT) sensor is located on the Solenoid Pack inside the transmission:
https://www.supermotors.net/getfile/...enoid-body.jpg You have to remove the transmission oil pan to get to it. Why do you think you may have a bad sensor? |
Originally Posted by rla2005
(Post 12677661)
should be a plug on passenger side top of the lip above the pan
try some contact cleaner then dielectric grease chech the pins for corrosion or being bent over-the whole pack comes as a unit-last one I got was around $300 from Ford had no luck finding it any place else :( |
Thanks. I have contact cleaner and dielectric grease so I'll give that a shot today.
Originally Posted by jr32560
(Post 12677690)
Originally Posted by erupert66
(Post 12677671)
Getting a code on it and looking for possible sources for firm downshifts. From perusing other threads, the suggestion is to clean the connection. I assume there is a harness connection on the side of the tranny somewhere
(Post 12683059)
If the transmission (and engine) was not warmed before running the KOEO tests this code is very common and not valid.
Thanks, good to know. |
