Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum28/)
-   -   something ive always wanted to know (http://www.ford-trucks.com/forums/1211929-something-ive-always-wanted-to-know.html)
npd23 12-24-2012 11:21 AM
ever since i first got my 93 f150 ive always wondered to myself how much higher the stock 4wd 250 sits compared to something like my stock 4wd f150. i love the look of the stock f250s with 33s on it and i really would like to know how much lift i need to sit exactly like that..
woosterken 12-24-2012 12:12 PM
every body here on the forum says to put the coil springs from a 250 in our 150 , it will give like 2" of lift to the front.
there should be enough room in the rear for the 33's :)
with the spring change you will not need longer shocks,unless your going major off road.
ken
MaineFordLover93 12-24-2012 12:36 PM
Have a 94 f-150 and i put the 2 inch leveling coils from jeff's bronco graveyard and tried and tried to get the camber right but ended up bringing it too a shop and they couldn't figure it out so i had to buy the 2 inch i-beam drop brackets another 150 bucks!!
npd23 12-24-2012 01:31 PM
thanks so much! I ended up putting a full two inch lift in it now I just need the money to actually get tires! but I ordered and installed coil spring spacers and a inch and a half block for the rear I was just concerned on if that'll sit it like a stock 250 with bigger tires cause it's hard to tell with stock tires !? thanks for the help guys!
