Special tools-Automatic Transmission -4R70E/4R75E- 5R55S, Rear /Front Drive Axle/Differential— Dana
This set includes :
501-025 Rear View Mirror Installer 412-098 Holding Fixture, Compressor Clutch 204-182 Remover, Ball Joint 303-474 Installer, Crankshaft Front Oil Seal 4.2L, 3.9L : F 150;Mustang;Freestar;Mark Lt ;Monterey : 2004-2008 307-309 Remover, Torque Converter Fluid Seal Automatic Transmission -4R70E/4R75E- 5R55S, Rear /Front Drive Axle/Differential— Dana 30;Sable;Milan ;Mountaineer;Grand Marquis 2004-2011 307-310 Remover, Lube Tube 307-311 Protector, Piston Seal 307-312 Air Test Plate, Transmission 307-314 Remover, Reverse Clutch/Planet 307-315 Installer, Lube Tube Fluid Seal 307-316 Remover/Installer, Front Clutch 307-317 Aligner, Output Shaft Fluid Seal 307-318 Remover, Stator Bearing 307-319 Protector, Piston Seal 307-320 Shim Selection Gauge 307-321 Shim Depth Gauge 307-322 Protector, Piston Seal These Tools was moved after Ford dealership closure. $ 125.00 FOR ALL or best offer- "No reasonable offer will be refused!" raybx01@gmail.com or Please Call Ray at 512-845-4844 We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request. I can ship Overnight or two day shipping. You decide, you are in control.( I do not ship overseas) http://i1275.photobucket.com/albums/...ps74161fb8.jpg http://i1275.photobucket.com/albums/...psd10e9acb.jpg |
