Ford Truck Enthusiasts Forums
-   1957 - 1960 F100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum268/)
-   -   matching gears on 4x4 1959 (http://www.ford-trucks.com/forums/1209965-matching-gears-on-4x4-1959-a.html)
mtdorf 12-15-2012 05:19 AM
I have always been told that the front gears are one or two teeth higher then the rear end on the older Ford pickups. I have a 1959 F100 4x4 with 4:10 gears and want to put in higher gears. Before purchasing I want to know if the front gears are higher then the rear.
Thanks in advance for your responses
KingBigJoe 12-15-2012 09:28 AM
Yes, it is true. But, it doesn't really hurt anything as long as you don't have the front axle locked & the 4x4 engaged on dry driving surfaces (pavement). Having a slightly higher [by .01 or .02] (meaning lower numbered ratio) gears in the front axle help pull the rear axle a little (helps with steering) & supposedly help prevent driveline bind a little.
theodore/teddy 12-15-2012 09:47 AM
The original 59 F100 4x4 had a difference of .03 front to back, back 3.89:1 front 3.92:1.
I only point this out because you state
so you may want confirm your ratio.
Good luck in your quest.
mtdorf 12-15-2012 08:09 PM
Thanks for the info from both of you guys! I will do some checking see what I come up with for the ratio.
Thanks again.
