Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum41/)
-   -   '56 F600 sheet metal on '56 F100 frame (https://www.ford-trucks.com/forums/1209964-56-f600-sheet-metal-on-56-f100-frame.html)
iforeman 12-15-2012 04:31 AM
Hiya all
What would I need to do to make a F600 sheet metal (Cab and front fenders,etc.) fit onto a F100 Frame. (if anything)
Thanks
Ian
tacson 12-15-2012 06:00 AM
I honestly dont think anything. You are aware that the fenders from a F600 have a wider wheel opening though correct? Thanks
56panelford 12-15-2012 08:38 AM
All the mounting points are the same and as tacson mentioned the wheel well opening are much larger than the F-100. The rear portion of the fender sits lower than the F-100 also because the running boards are lower on a F-600 probably because the frame is 8 inches compared to the 6 inches on the F-100
56panelford 12-15-2012 08:43 AM
Sorry this ended up as a second try posting/ internet glitch
cristian75 01-31-2013 09:51 PM
Hi there, planning to do the opposite way, put the f100 body into a modern f350 frame and will need the F600 fenders. In case you want to use the smaller f100 ones just let me know and we can trade them.
Thanks!
earthquake68 01-31-2013 10:00 PM
You'll need a lift kit. The fender bottoms will drag the ground. Other than that, they'll bolt on.
POS-F500 01-31-2013 11:24 PM
Thanks!
Where are you located? I have a nice pair of F500 fenders and I'd like to get a better driver's fender.
cristian75 02-01-2013 06:54 AM
I'm in Miami, Fl, 33166.
Thanks!
