[Tutorial] 2013 SuperCab Door Panel Removal
I figured I'd write up this brief description on how to remove the door panel on the Supercab F150 as I didn't really find a good description of this process. I did this on my 2013 but I imagine its similar if not the exact same for the 2009+.
First is to remove the single screw at the bottom of the door panel. http://imageshack.us/a/img21/7632/20121208114548.jpg Next, remove the two screws on the side of the door panel. You can find them on the side that opens outward. http://imageshack.us/a/img685/389/20121208114530.jpg Next, remove the power window switch. http://imageshack.us/a/img717/7741/20121208114541.jpg Next, remove the molding on either side of the window. It should just pop off, but I recommend using hard plastic tool sets that you can get from most hardware stores. 5 Piece Auto Trim and Molding Tool Set You will need to remove the seatbelt before removing the molding behind it. Just pull on the plastic piece below the piece that says "pull", the one that says "pull" is to adjust the height of the seatbelt. The one you need to remove is just below it. You will need a star bit to remove the belt. One screw on either side will need to be removed. http://imageshack.us/a/img855/6787/20121208114538.jpg http://imageshack.us/a/img62/3485/20121208114535.jpg Finally, there are two screws in the door handle itself. Remove them and then remove the door handle form the door panel. You should be able to remove the door panel leaving the handle attached to the door. http://imageshack.us/a/img201/9262/20121208114647.jpg http://imageshack.us/a/img831/8649/20121208114854.jpg |
Thanks for the info
Don't know if you still access the site.
Just got a new to me 2011 F150 supercab.... just making it mine... couldn't handle the factory speakers... this helped. Thanks |
12 Attachment(s)
Old post I know, but I had a horrible buzz/rattle in my 2013 rear left scab door and these were the best instructions I could find. I snapped a few pics as I stumbled along hoping to help the next guy/gal.
Originally Posted by Casey_78
(Post 12577498)
Attachment 209847 http://imageshack.us/a/img21/7632/20121208114548.jpg
(Post 12577498)
http://i4.photobucket.com/albums/y10...ps4zugdbj0.jpg Attachment 209848
(Post 12577498)
(Post 12577498)
Attachment 209849 Attachment 209850 Now the right side
(Post 12577498)
Attachment 209851 Attachment 209852 Then pull/wiggle from the top. Attachment 209853
(Post 12577498)
One screw on either side of the window will need to be removed.
Attachment 209854 Attachment 209855
(Post 12577498)
Attachment 209856 Attachment 209857 Kind of lift up on and wiggle the panel, it'll pop off towards you. It was here that I unplugged the window switch. Attachment 209858 I popped the switch out before re-installation and fed the plug up thru the hole and snapped the switch in place afterwards. |
2 Attachment(s)
Now, it's been rainy here for 2 days but imagine my surprise to find a wet speaker. Speaker mount screws take a 7/32" nutdriver. 6mm is too big, 5 mm too small.
Attachment 209845 All the little pieces of foam used for rattle isolators, the speaker, latch cables- all wet. I added some soft adhesive-backed foam to the inside & outside of the speaker as well as cutting a freezer bag and putting a "poncho" over the speaker inside the door when re-mounting. There were now puddles in the door. Time I guess for new weather sealant! This last pic is the panel installed, you can see what I meant about "feed the window switch wire up thru". The window switch snaps back into place after plugging in. Attachment 209846 I also noticed lots of "looseness" on the plastic panel against the door after I re-installed it. If the buzz/rattle comes back I might have to foam that too. We'll see. Hope these pics help! |
Originally Posted by rbentnail
(Post 16833961)
