Upgrading Glow Plugs for 7.3
The Beast is slugglish to crank sometimes, it turns over but hesitates to start. I have 2 new OPTIMA Red Top batteries & a new starter. Was thinking about
up-grading OEM glow plugs & glow plug module to Diesel Rx ones. Has anyone ever used this brand of glow plugs & glow plug module? If so, how do they compare to OEM performance? Thx |
Do NOT use anything other than OEM Motorcraft glow plugs.
Riffraff Diesel: Motorcraft Glowplugs ZD-11 There's no better glow plug. No such thing as an upgrade when it comes to GP's. Determine why your Ex is sluggish. Don't just throw parts at it. Stewart PS - Where are you located? |
I just checked their website and don't even see where they offer Glow Plug Control Modules, just Glow Plug Relays. So unless you've modded your Ex to use GPR's, you're gonna have to stick with the GPCM.
Stewart |
Thanks Stewart_H, I will make sure I use OEM gp's for sure
Originally Posted by Luvmy7.3Ex
(Post 12543126)
My the check engine light comes on and keeps coming back despite being cleared, so it looks like glow plug number 6 is at it again. Since I fixed the same problem 2 years ago with a used GPR, I figured it's time for the Guzzle GPR relay fix. Start my reading and it says that Exs and those with CA emissions can't do the mod - darn.
What to do next, I know, check FTE and search King of the SUVs because its an Ex specific 7.3 problem. The first search result heads me in the right direction:
Originally Posted by Stewart_H
(Post 12542129)
Riffraff Diesel: Motorcraft Glowplugs ZD-11 There's no better glow plug. No such thing as an upgrade when it comes to GP's. Determine why your Ex is sluggish. Don't just throw parts at it. Stewart |
Stewart is right all the way. OEM glow plugs only! Just did mine when I put it wedges and re-ringed the injectors. Made a big difference. Didn't realize how tired they were:-X04
On EDIT: Take a look at your battery cables. I had to replace mine at 140K due to the cables corroding under the red covering. Mine had a similar problem that I thought was batteries. When I took the cable off, you could bend it and hear the copper fracturing on the inside. None of the corrosion could be seen. Again, buy only Ford cables if yours are doing this. It solved my problem. |
Originally Posted by JumpinJoe
(Post 12640894)
... Since I fixed the same problem 2 years ago with a used GPR
I figured it's time for the Guzzle GPR relay fix. Start my reading and it says that Exs and those with CA emissions can't do the mod - darn. So, since I'm going with motorcraft all the way here, should I just replace the relay? Stewart |
I you go into the valve cover might as well replace them all. No point saving $30 on one side if you have to do it again.
JJ, do you have a GPCM like in this pic...
http://i59.photobucket.com/albums/g3...0Underhood.jpg Or a GPR like in this pic? http://i59.photobucket.com/albums/g3...ineSensors.jpg Stewart |
A GPR can't set a code and tell you that #6 is bad. Stewart is right, if you replaced a relay, you replaced the AIH. Now it's time to fix the GPCM (or the wiring or #6 glow plug if it doesn't ohm out correctly)
Confirmed, thanks to the pictures - I have a Glow Plug Control Module (GPCM) and a AIH Relay. Can't remember which one was replaced last time. But from the looks of it, I'd say the AIH is original to her. I'll start with that and work with it. Thanks Everyone.
Tried to rep you Stewart but I am in rep jail yet.
