Lightning Rearend 9.75 HELP!!!
My '04 Lightning was in an accident and the rearend is damaged.
Where can i get a 9.75 lightning rear end? Do all 1997-2004 heritage 9.75 rear ends have the same shock mounts? Are there any other f150s with stock sway bar mounts? If not, can i use the sway bar mounts off of the damaged rearend and weld them to a normal f150 rear? |
If you are handy go for it ? Grind, sand, clean it good, U want a tru surface to mount to, no rock-N, a little heat and MIG it for sure. N on cherry red glow of the items.
only the Lightings have the rear sway bar mounting tabs, but you can transfer 'em over to a "normal F-150" 9.75
