Bronco Custom 1979 400 rebuild
Hi Guys, Im from Argentina and this was my engine rebuild project
Bronco 400 with TMI pistons, the first one here. this is my 79 bronco custom, it has a 351M engine with C6 auto trans. https://img191.imageshack.us/img191/1135/img4916k.jpg I got 400 crank and pistons, and IŽll swap the C6 for a ZF5 manual trans. I turned off the engine in may 2010... :-jammin |
First I got an used Edelbrock Performer 400 intake, but I sold it and finally I got this brand new weiand action plus +
https://img41.imageshack.us/img41/7276/img5265zc.jpg https://img594.imageshack.us/img594/7385/img5266e.jpg https://img411.imageshack.us/img411/5828/img5267i.jpg https://img109.imageshack.us/img109/8537/img5268w.jpg https://img13.imageshack.us/img13/1381/img5269f.jpg |
oil pan and the carburetor
https://img413.imageshack.us/img413/8622/img5427r.jpg Barry Grant Demon 625CFM https://img52.imageshack.us/img52/1552/img5451v.jpg https://img15.imageshack.us/img15/1848/img5452m.jpg https://img204.imageshack.us/img204/6209/img5453pq.jpg https://img14.imageshack.us/img14/1585/img5454bv.jpg https://img63.imageshack.us/img63/7291/img5455q.jpg https://img188.imageshack.us/img188/2435/img5463w.jpg https://img190.imageshack.us/img190/8494/img5465a.jpg |
Tmeyer sent me these
400 Hypereutectic Piston 9,3:1 Premium Rings Kit Gasket Set Expansion Plugs, Brass Oil Pump SBF Lifters "335" series-Gear Drive-Quiet Ultra Slick Engine Assy. Lube Plastigage ZDDP oil additive- 4oz. bottle Cam Bearing Set- Grooved Valve Spring, Retainer and Locks kit HARMONIC BALANCER Engine Bolt Kit- 351M/400 400 Crankshaft Kit rod and Main bearings 351M/400 Push Rods BBF Roller Rocker Arms 1.650" Exhaust Valve 2.040" Intake Valve 351M/400-Water Pump |
https://img819.imageshack.us/img819/...6052011250.jpg
https://img577.imageshack.us/img577/774/26052011251.jpg https://img38.imageshack.us/img38/9008/26052011252.jpg https://img11.imageshack.us/img11/7357/26052011253.jpg https://img26.imageshack.us/img26/2482/26052011254.jpg https://img35.imageshack.us/img35/8253/26052011255.jpg https://img853.imageshack.us/img853/...6052011256.jpg https://img32.imageshack.us/img32/3826/26052011257.jpg https://img37.imageshack.us/img37/3656/26052011258.jpg |
you can see a friend working, also he is developing the new Radius Arm Drop Brackets for my custom.
https://img827.imageshack.us/img827/39/28052011264.jpg https://img218.imageshack.us/img218/...8052011267.jpg https://img52.imageshack.us/img52/9485/28052011266.jpg |
https://img23.imageshack.us/img23/6497/31052011270.jpg
https://img854.imageshack.us/img854/...1052011272.jpg https://img715.imageshack.us/img715/...1052011273.jpg https://img3.imageshack.us/img3/1633/31052011275.jpg https://img691.imageshack.us/img691/948/31052011276.jpg https://img836.imageshack.us/img836/...1052011277.jpg |
https://img195.imageshack.us/img195/...2062011292.jpg
https://img89.imageshack.us/img89/5036/02062011293.jpg https://img853.imageshack.us/img853/...2062011294.jpg https://img13.imageshack.us/img13/8018/02062011295.jpg https://img829.imageshack.us/img829/...2062011298.jpg https://img51.imageshack.us/img51/8098/02062011299.jpg |
http://img707.imageshack.us/img707/510/04062011300.jpg
http://img705.imageshack.us/img705/5568/04062011301.jpg http://img842.imageshack.us/img842/2572/04062011302.jpg http://img3.imageshack.us/img3/5366/04062011303.jpg http://img851.imageshack.us/img851/8306/04062011304.jpg http://img717.imageshack.us/img717/3696/04062011305.jpg http://img228.imageshack.us/img228/5831/04062011306.jpg http://img146.imageshack.us/img146/6962/04062011307.jpg http://img685.imageshack.us/img685/3600/04062011308.jpg |
