Originally Posted by glovemeister
(Post 12470076)
These don't require fuel plates, that is a Cummins thing IIRC.
You need: 3 inch downpipe with your exhaust mods, 6637 intake, boost and egt gauges so you don't melt down your motor After that there is always: Electric fuel Bigger Turbo Bigger Injectors Built auto or SMF conversion and built clutch if 5spd. |
Diff yes syn.trans and case yea.engine,that is a personal choice.just depends on who you talk to.
If you have any oil leaks fix them be for you run synthetic. They will leak faster with synthetic
Originally Posted by dcase13
(Post 12470110)
Good to know thanks! Is there an oil you recommend for the motor, transfercase, and diffs? With 270k should I run a synthetic blend?
I run Delo 15/40. Walmart in Medford had it on sale last week. Havent changed my diff's since I bought the truck yet.
So,you are getting it tomorrow then?
