Ashtray...how do I fix it?
To open the ashtray you push inward and it pops out.
I pushed it inward and it went further in and now it won't stay in the shut position. How do you remove it or fix it? I didn't want to go to the dealership. |
most likely 1 or both of the flat springs are broken or missing. To remove you can get a small flat screwdriver to work it out of the depressed position. There are 2 release clips, similar to a cabinet drawer, under the cupholder/ ashtray to pull it completely out. Most likely you'll need a new ashtray.
from another site;
ashtray/cupholder fix? - F150online Forums or with pixs; Ashtray/Cupholder messed up - F150online Forums |
:-X22 thank you for the links with the pictures. when i get some spare time i will fix it....thanks again. i will update this thread once i do the repair.
I fixed my ashtray. Used 2 screws and popped it back in the dash and it works better than new! Thanks once again. :-X22
