Cummins in Ford
I own a 99 ram with the cummins, tranny rebuilt once at 65k, truck now has 89k. When I was at Cummins Power Systems buying a fuel filter, the man at the counter said that Ford was putting the cummins in their 2005 model pickups. Has anybody heard this???? Looking into purchasing another Ford one day but would like to have the cummins motor
Cummins in Ford
This isn't true. You can get a conversion kit to install a Cummins in a Ford pickup, but Ford isn't offering it as a factory option. If you want the 5.9 Cummins in a Ford you'll have to buy an F650 or F750, and at that point I'd get the Cat diesel.
Cummins in Ford
So your saying if i order a new 350, i can request a cummins or order it without a motor and have it installed
Cummins in Ford
Originally posted by jjsj38 So your saying if i order a new 350, i can request a cummins or order it without a motor and have it installed |
Cummins in Ford
you can get the cummins in ALL the fleet model trucks. From the 350 on up.
Cummins in Ford
i want the f 350, so it doesn't come in the f series
Cummins in Ford
I just went to Ford's commercial website and there are no 5.9 Cummins options for anything smaller than F-650.
Cummins in Ford
I thought they were offering them in the "fleet" line, but that's been a couple months since I checked the website tho.....
Cummins in Ford
Originally posted by johnsdiesel This isn't true. You can get a conversion kit to install a Cummins in a Ford pickup, but Ford isn't offering it as a factory option. If you want the 5.9 Cummins in a Ford you'll have to buy an F650 or F750, and at that point I'd get the Cat diesel. |
Cummins in Ford
yes there is only 1 5.9 Cummins diesel. The one they put in the Ford trucks are the same one the put in the dodge trucks. You can get a quiet 305hp F-650 now I thought that was kinda funny sense Ford and Dodge keep figthing for the higher HP diesel and if you buy Ford you can get both. It would make a great comparison. same truck same load different engine.
Cummins in Ford
Check out the Ford F100 from the Ford-argentina web site. They sell in Argentina, an F100 pickup that looks exactly like an F250, and they DO, in fact, put a 5.9L Cummings in the truck!
Cummins in Ford
The Cummins they're using in the F650 and F750 is the same engine that is used in the Dodge pickups, but it is tuned differently. There are 5 different "tunings" of this engine available:
185 HP @2400 RPM 420 lb/ft @1600 RPM 215 HP @2300 RPM 520 lb/ft @1600 RPM 230 HP @2300 RPM 520 lb/ft @1600 RPM 245 HP @2300 RPM 660 lb/ft @1600 RPM 260 HP @2300 RPM 660 lb/ft @2500 RPM |
cummins in 93 F250
Is there any easy way to put a Cummins diesel in a 93 F250 to replace the current Navistar engine?
Way to bump a 6 yr old thread.
Originally Posted by BigDaddy6969
(Post 7985605)
