Ford Truck Enthusiasts Forums
-   1973 - 1979 F-100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum38/)
-   -   Dually front end question (http://www.ford-trucks.com/forums/1201360-dually-front-end-question.html)
old blue beast 11-06-2012 04:18 PM
I've got a 77' F-350 supercab camper special that im converting to a dually. I was wondering if the front hub adapters off my 74' F-350 DRW would fit, they just bolt to the disk's.
crazyredneckanyhow 11-06-2012 06:13 PM
the rotors are usually different. Spindles may also be different.
kobaltblue 11-06-2012 06:46 PM
If they bolt on they should bolt on the other.
crazyredneckanyhow 11-06-2012 06:49 PM
Its not always that simple with the fords. A none dually rotor will have different holes in it that a dually rotor. The single wheel rotor has holes for wheelstuds whereas the dually rotor has holes for normal bolts. Im also thinking the rotors have a different backset. I have a dually frontend setup out of a 75 layin in my scrap pile if youd like some pics.
crazyredneckanyhow 11-06-2012 07:05 PM
couple parts to look at.
single wheel rotor
Buy Wearever Brake Rotor - Front YH141153 at Advance Auto Parts
dual wheel rotor
Buy Wearever Brake Rotor - Front YH141505 at Advance Auto Parts
Might also check with advance or napa on wheel bearing part numbers to make sure the dual wheelhubs will fit on a single wheel spindle
NumberDummy 11-06-2012 07:20 PM
It all depends on the serial number, which is the last 6 digits of the VIN
D5UZ-1102-B .. Hub & Rotor Assy / 1975 E350 SRW/DRW / 1975 F350 SRW/DRW from serial number V80,001 / 1976/79 F350 SRW/DRW
1973/74, 1975 before serial number V80,001 not the same.
D5TZ-3105-E Right & D5TZ-3106-E Left .. Front Spindles / 1975 F350 SRW/DRW from serial number W40,001 / 1976/79 F350 SRW/DRW
1973/74 & 1975 before serial W40,001 not the same.
Source: 1973/79 Ford Light Truck Parts Catalog / Text Section 11.1 (Hub & Rotor-various parts lists) / Text Section 30, Parts List 30.2J (spindles).
crazyredneckanyhow 11-06-2012 07:26 PM
Bill what i gather from that is depending on serial # the spindles are the same? What im not understanding is your info on the hub/rotor assembly. Is the rotor the same but uses a spacer in the drw version? Ive had the 2wd F-350 in both the srw and drw and i dont remember the rotors being the same. However i could be wrong. It seems to me that the drw setup i have not has a deeper "dish" to the back where the spacer bolts than the srw where the hub/rotor come together. Also bill out of pure curiousity are the srw version a floating rotor or does it attach to the back of the hub with the wheel studs pressed through?
NumberDummy 11-06-2012 07:38 PM
I have no clue if the rotors float or not, parts catalog doesn't say. Since they're steel, they'd sink faster than the RMS Titanic. :-X04
1973/74 & 1975 before serial number V80,001: hub is different, rotor is different. These parts were sold individually.
1975 from serial number V80,001, 1976/79: Hub & Rotor sold as a one piece assembly.
1973/74, 1975 before serial number W40,000 use different spindles (D2TZ-3105-A right / D2TZ-3106-A left) than 1975 from serial number W40,001, 1976/79.
Same spindles used on F250's. Weight capacity of front axle different before serial number W40,001.
old blue beast 11-07-2012 06:18 PM
This is what the hub looks like on the towtruck
http://www.ford-trucks.com/forums/at...1&d=1198851301
old blue beast 11-07-2012 06:21 PM
Minus the snow.... for now anyway:-jammin
