Pids not pix
Thats an Insight CTS you have right?
Here is what it is supposed to support. If you are missing any of these you either should call and find out why or dig a bit deeper. "Ford 2003-2007 6.0L Powerstroke Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed (03-04), Engine Coolant Temp, Engine Load, Engine Oil Temp, Engine RPM, Engine Run Time, FICM Voltage, Gear with TCL, ICP Pressure, Injector Pulse Width, Intake Air Temp, Mass Air Flow, Mileage Coach, MPG Instant, MPG Average, TCC Duty Cycle, Time 0-60, Time 1/4 mile, Trans Temp, Turbo Boost, Vehicle Speed (04-07), Variable Geometry Turbo Duty Cycle" |
Just got a email from sct tech desk they will reflash my stock tune with the vin so that when I plug it in my car the PCM will have the vin in it so when I plug my cts in it will read the correct pids
Thanks for the help Tim I think is just a 03 04 problem due to the PCM not having the vin per programmed in the PCM
I knew it!
Looks like i'm the only one up. Y'all enjoy your Saturday morning.
Howdy guys, have a good weekend.......:)
Howdy Devin Tim & all
Morning Virginia, Tim, Devin, Gerry, Mathew,and all. Warmer in NY than here in Stuart. Does that mean the politicians have more hot air up there? I know manure creates heat...
Same thing George........
Morning all
hey pplz...
Morning everyone! Where am I!
Day after the night before, huh Tim??
Yup, wild night. How are you today George?
