2008 Edge ABS Tone Ring
I am new here, but have been searching the posts for information on this. I apologize if I missed a post.
Lady in my life has a 2008 Edge Limited FWD and the ABS light goes on at hwy speeds. Turns out that the right side ABS Tone Ring is cracked and needs replacement. From everything I can see, this is a replaceable part and many on this forum have replaced them on the Escape. My issue is that I can not find a part number for the Tone Ring for the 2008 Edge. The replacement for this from the Ford dealer and everywhere else I look is to replace the entire half-shaft. Seems a bit excessive for a Tone Ring replacement. I've seen on here where people have glued their cracked rings as well. Has this been successful long term for anyone (say... 30K miles or more)? Any other thoughts or suggestions are welcome. thank you! I apologize for posting in the wrong sub category. I'm trying to move it to the Edge forum |
Moved to Crossover forum :-tap
Welcome to FTE! |
Thank you! my apologizes...
I hate to dig up old posts, but I'm after the same information. Is there another ford model with the same ring size for the 2008? Seems crazy to not have them for the Edge. As said above, I can find the half assembly, but only need the ring. Any help? Thanks
