Generator fuel consumption
Anyone know about how much fuel a 6000 watt generator uses? It's a Dewalt DG6000 with a Honda 11hp engine.
The specs are on DeWalt's site here:
DXGN6000 6000 Watt Commercial Generator | DEWALT Tools It says 14hrs run time on 8gallons of fuel at 50% load, so a little over 1/2 gallon per hour. |
Mines an older model but should be about the same... Thanks. The 12 gallons of fuel I have should run about 24 hrs... Now I KNOW we won't lose power!
I have a 2004 model Craftsman with a 10HP briggs. 5600 running watts and 8600 surge.
I backfeed my breaker panel and run the water heater, power to all lights and outlets in the house and she runs great. It seems to use 5 gallons in about 14-16 hours of continuous use. Fortunately it's only needed about once a year. However, I do start it monthly and let it get good and warmed up. |
Originally Posted by tseekins
(Post 12422128)
I'm going to turn the main off, pull the 30a breaker to the dryer and hook it up to a piece of 8/3 copper wire that I put a plug on the other end, plug it into the 4 prong generator outlet, put the breaker back in and back feed the panel.
Originally Posted by 85e150six4mtod
(Post 12422177)
Do you use a switch or just turn off the main and backfeed another set of breakers?
Originally Posted by bashby
(Post 12422293)
I know it's not a good solution to an otherwise safe alternative. I'm very aware of what's happening around me and I'm extremely careful to shutdown the genny, unplug all connections and restore all previous connections prior to restoring street power to the house. When I raise the money, I want to have a gas standby generator professionally installed with the auto transfer switch and the whole nine yards. Not sure if I can justify the cost for a whole house model. I'd likely need a 12K-15K model to run the a/c and everything. |
I have heard the dryer plug is a good way to do it, but our panel is in the attached garage, so all I have to do is roll the generator out of the door then make the connection to the breaker.
I don't see any reason to get a transfer switch if you understand why you need the main off. I've never actually done it myself, but a buddy of mine does it that way all the time. He also wired a light fixture above the panel that is connected to the lines coming in from the meter. When he's running the generator, he will screw the light bulb in the last half turn, then when the light comes on, the power is restored then he can shut the generator down and go back on the grid. |
(Post 12422005)
Your part of the country has not had the infrastructure hardened to withstand the damage a hurricane will bring. I stock 110 gallons of ethanol free gasoline in two 55 gallon plastic drums when a storm is coming. I also have spare air filters and oil for the genset. CAUTION rain will create a very dangerous condition around the generator. THE SHOCK HAZARD IS A MAJOR CONCERN. The risk of carbon monoxide is another concern. Use your generator to keep the refrigerator cold a few hours a day. Maybe turn the tv on for news at the same time. Pulling a 1000 watts or less will extend your available run time. I wish you the best of luck. |
My dad has a pto generator that he hooks up to our 40 horse ford tractor. It has enough wattage to run the whole house but we usually just use whats necessary. Thats what we used when we were out for 8 days last halloween.
That reminds me, I need to convert my 5.5 kW generator to run off my 500 gallon propane tank....
That 10 HP Tecumseh would run a really loooong time off that tank. |
bashby I see you are on line at the moment.
How did you do with the 12 gallons of Gas for the generator? Was it enough for your needs? |
i have a 10KW onan genset. i am powering 3 houses, and use about 1 gallon per hour.
when the heaters, refrigerators, and freezers are not running, fuel consumption drops to 1/2 gallon per hour. |
When I raise the money, I want to have a gas standby generator professionally installed with the auto transfer switch and the whole nine yards. Not sure if I can justify the cost for a whole house model. I'd likely need a 12K-15K model to run the a/c and everything. Since "the moment you buy a machine it starts to age" I'll wait until I really need one to have it delivered. I can't justify a whole-house genset since I have gas heat as backup and a gas stove, and if summer gets nasty the pool will still work without the pump running. A welder makes a nice mobile power source, and welding machines tend to pay themselves off quickly. ------ I use G.I. water cans for fuel (they work fine, I filled mine then threw 'em around my driveway to test) and their caps are ideal for filling small engines. (I don't transport ANY gas cans inside a vehicle.) water cans...Plastic/Metal? - Expedition Portal |
