Which type of bedliner should i use?
I am going to bedline the interior of my cab. What type of bedliner is best? and should i use the roll on or spray on kind?
Linex is what I have used and I highly recomend it.
Line-X is the best in my opinion.
X3 for line x
Realistically it depends on what you plan to use the bed for.
line x would be a royal pain in the rear end to do on the interior. Just pick up a roll on bed liner kit and have at it. Dont forget to prep properly
I currently have a roll on bedliner, not sure what brand. Nice and thick, only been replaced once. If your bed will be getting a lot of use, I'd use a roll on myself, but then again I have not tried a spray on bed liner either. YMMV.
Just had a linex liner put in my new truck. Couldn't be happier. It was completed for $370 and I have no doubt it will last the life of my truck.
LINE-X Premium (so it won't fade).
Originally Posted by XPD77
(Post 12454774)
I like my bedrug....they run about $350, lifetime warranty
I ended up getting the line-x on Friday, ordered the ARE cap on Thursday... . Said it will be in around 4 weeks...
I have had the several spray in bed liners and I went with the dual liner this time. Initial install took about 30 - 45 mins. But I have the factory 5th wheel hitch in my truck so I had to do some modifications which took me about 6 hrs. To cut out the side panel and rubber floor mat for the hitch and electrical connector. Check out my photo album there is a pic there. I would have posted here but couldn't get the URL copied on my iPad to paste into post. They also have a discount code here in this thread. So far I'm very pleased with it.
