2005 - 2008 Ford F150 Truck Window Regulator Power w/Motor for Regular Cab/Crew Cab Model Passenger
http://www2.1aauto.com/_include/gui/logo_large.gif
BUY HERE: 2005 - 2008 Ford F150 Truck Window Regulator Power with Motor for Regular Cab and for Crew Cab Models Front Door Passenger Side http://static.1aautoimages.com/parti...01053/main.JPG This replacement power window regulator with motor is just what you need to get your Ford F150 & Lincoln LT in good shape again! This power window regulator with motor features the following specifications: RH (Passenger Side) FRONT DOOR Replaces dealer part numbers: 4L3Z1523200BA, 4L3Z 1523200 BA, 4L3Z1523200CA, 4L3Z 1523200 CA, 6L3Z1523200BA, 6L3Z 1523200 BA Power operation Direct replacement Includes power window motor already assembled to regulator Built to strict quality control standards Fits Regular & Crew Cab models only Regular Cab has 2 Full Size Doors Crew cab has 4 Full size doors Does not fit Super Cab models Super Cab has 2 full size doors & 2 half doors This Ford F150 & Lincoln LT window regulator with motor makes a great replacement and has good cost savings over a dealer unit. Installation: This repair is easier than you may think. You'll find our installation tips helpful. In our experience removing and replacing the door panel is the most involved step in the repair. On most vehicles this only requires removing a few screws and push in clips. You'll get a great feeling of accomplishment after you complete this repair knowing you saved money and you didn't have to give up your car for a day at the repair shop. Your passengers and other drivers will be amazed. Fit guaranteed 1A Auto will refund you with no hassle, if this Window regulator does not fit the application stated. You can use your existing hardware and wiring harnesses. This Regulator will install just as your original does. Save time and money. Quality 2 Year Warranty. Don't worry, if this regulator should fail to provide satisfactory performance you can exchange it. Be confident this part will work right. Every regulator is tested after assembly to make sure the cables and all mechanisms are working correctly. It is important that your new regulator works for a long period of time. The design of this regulator is tested to withstand 10,000 cycles. That is enough to raise and lower your window 3 times per day for 9 years. Nothing is more frustrating than taking your car apart and finding the part you purchased does not fit. You want the part to fit. This design is test fit on an actual door. When you install it you will have no issues. Value Windows that don't work can be frustrating. They can also hurt your vehicles value. An inoperable window could mean $200-$500 discounted off a dealer trade value or asking price. Some shops and dealers charge more for parts and repairs when they think you don't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly repair bill. |
