Ford Truck Enthusiasts Forums
-   1973 - 1979 F-100 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum38/)
-   -   Dual exhaust (http://www.ford-trucks.com/forums/1185107-dual-exhaust.html)
77 2wd 08-25-2012 02:41 PM
Dual exhaust
Putting a 429 in my truck, alrighty got a set of dual headers, i need advice on what kind of dual exhaust to run, any suggestions on muffler glass packs all those goodies?
montana_highboy 08-25-2012 03:05 PM
2.5" pipe, X or H pipe about a foot behind the collectors (if you can fit it) if not, true duals are just fine too, free flowing muffler/glasspack, terminate it to your liking e.g. at the rear wheels, under the bumper, etc.
77 2wd 08-25-2012 03:19 PM
Quote:
alright, so when i go to my muffler shop tell em 2.5" pipe with an X pipe preferably behind the collectors, and glasspacks? ive heard good things about flowaster 40's, is that what they call a certain muffler?
HIO Silver 08-25-2012 03:42 PM
Quote:
No. Glasspacks are just like the word says. It's made with a perforated inner tube wrapped with fiberglass packing to absorb the sound waves. Then it is inserted in a steel tube. Then the outer tube's the ends are spun down and welded to the inner tube. More accurately, they should be called "glass-packed".
Flowmaster 40s are referred to as "welded mufflers" with a thick outer casing. Inside, the exhaust flow and sound waves are deflected with baffles for sound tuning and sound absorption. Sound waves that are 180 out of phase and meet each other in opposing directions cancel each other out. Flowmaster designs their mufflers to cancel out certain frequencies while maximizing flow given the application.
If you can weld, buy Speedway Motors' mandrel bent tubing kit and fab it yourself.
460 FORD MAN 08-25-2012 03:49 PM
I got a 460 with dual glasspacks and they sound loud and mean.
77 2wd 08-25-2012 03:56 PM
how much would that cost?? and should i go with glasspacks or flowmaster 40's ive heard great things about both!!
HIO Silver 08-25-2012 04:01 PM
A 2.5-inch mild steel kit is only $140 from Speedway... It's like $220 from Summit... save some moolah and apply what you save towards Flowmaster 40s. Around $90 apiece. Alternatively, I recall Summit just came out with Flowmaster-looking welded mufflers for about $30 each.
Personally, I avoid glasspacks because the fiberglass packing crumbles over time and all ya end up with is a 5hitty sounding ride. Relatively inexpensive yes but crappy quality.
YOU have to decide what is best for you. I went with Moroso Spiral Flows... $55 each, compact, no fiberglass, and no moving parts like Dynomax's VT muffler.. Btw, stay away from the VTs.. it's a stoopid gimmick.
77 2wd 08-25-2012 04:19 PM
Thanks! :-X06
460 FORD MAN 08-25-2012 05:08 PM
Hahaha, thanks HIO! :-X21
But you have to admit they sound good while they last!
HIO Silver 08-25-2012 06:19 PM
True... while they last.
410F-100 08-25-2012 07:03 PM
flowmaster is deffinatly the way to go... there are also a couple different types flowmaster 40, the super 40s will be louder than the deltas... check their sight,they have a few vids for a general idea.
flowmaster alos highly recomends a Hpipe over the Xpipes for bigger motors. X pipes tend to benefit smaller motors like 4 bangers...
jgavac 08-25-2012 08:47 PM
I lean towards glasspacks over flows. I personally think the flows sound a little odd on 460 trucks, but thats just me. If my truck had a smaller engine, say 351 or 302 I might have gone with flows.
$0.02
Jameson
dynamic 08-25-2012 08:50 PM
Personally I prefer the flowmaster super 40's. Love the sound.
410F-100 08-25-2012 09:10 PM
glasspacks do sound awsome on just about everything, but the glass tends to break down. i like the idea of baffles over glass. and stainless, never buy mufflers again!
i have a vw w/ a built vr6 that has a single delta 40 and a long resonater, but still fairly loud,and when it backfires its a piggy attracting bang!
montana_highboy 08-25-2012 11:42 PM
As far as glasspacks go it's like anything else, you get what you pay for, some are better than others.
I've been running "Jones PowerPack" glasspacks from "Full Line Exhaust" for over 8yrs (link below) and they've yet to blow out and still sound great.
They're 14 gauge aluminized steel, perforated core, which holds the 'glass' in better than a louvered core glasspack does, the perforated core also creates less back pressure.
They're also made in the USA.
Full Line Exhaust - Glasspacks
