60 F100 Dash ?
I started restoring the inside of the cab of my 60. This might be a dumb question, but how the heck do you take off the control knobs on the dash? I figured they just twisted on or off but I can't seem to figure it out.
there should be a little set screw you need to take out. For the headlight switch I think you push a tiny button on the bottom on the switch and the whole rod/knob comes out.
It depends on the switch/cable..
headlight switch: pull switch to on position then from backside of dash theres a small button thats easily felt...press it down fully then tug on the shaft and it will come straight out... Vent cables...the knobs arent removable from the cable...theres a nut on the backside of each...loosen that and pull the cable forward away from the dash for masking if you are painting. wiper switch...theres a set screw(allen head)...loosen it and the knob slides off the shaft.. The others are straight forward(cig. lighter and glove box door) - cs65 |
