Edge Evolution
I had a old Superchip in the truck when I bought it. It was losing connection and making my truck die at wierd times. Took it out and no problems for about a year and bam my computer went out. Put a re-built computer in there and all is fine. Just wanting a little more power up hills towing my travel trailer. Called Superchips and they said I could trade it in on a Edge product.
I choose the Evolution because I didn't have to do anything else to my truck. Plus I got it for $100 and they retail for over $350. Only use it in tow mode. Sometimes it will make my speedo jump around. I never did this when it was stock. It runs fine otherwise. Anybody else have a problem like this w/ an Edge tuner? My truck has 6637 and cat delete and 4" exhaust. Stock downpipe and that's it for upgrades. Thnx |
Shoulda stuck with the superchip.
The speedo jumping around shouldn't have anything to do with your PCM though. But then, the edge is a programmer, not a tuner. So, if it changes some weird thing I dont' know about then. *Shrugs* The VSS and that's in the rear axle and that controls the Speedo. Check the connection on it and make sure its tight and clean. |
Originally Posted by ramrod7373
(Post 12144770)
I choose the Evolution because I didn't have to do anything else to my truck. Plus I got it for $100 and they retail for over $350. Only use it in tow mode. Sometimes it will make my speedo jump around. I never did this when it was stock. It runs fine otherwise. Anybody else have a problem like this w/ an Edge tuner? My truck has 6637 and cat delete and 4" exhaust. Stock downpipe and that's it for upgrades. Thnx https://www.ford-trucks.com/forums/1...rogrammer.html :-drink |
The superchip was the old style that plugged into the side of the computer. I wasn't going to plug it back in and have the same problem again. Superchip doesnt make a tuner/programmer for my truck so I went w/ the one I could afford w/ out doing alot of expensive upgardes to my truck. I didn't notice a difference when I pulled the old chip out anyway. I DO notice a big difference w/ my truck in tow mode though. So I will prob roll with it this way and see what happens. I will send Edge an e-mail and see what they say.
Thnx for the input |
Nothing wrong with edge, just most of us here are against any style of programmer because they reflash the PCM instead of bypassing the pcm, so if it has a failed flash, you have a toast PCM and gotta send it to somebody who can flash PCMs.
Thats all. =) |
