Engine Perches or towers
Does anyone know where I can find a pair of Perches for a big block 460? Not sure where I can find them. Thanks
Originally Posted by 78 Custom
(Post 12062659)
(Post 12062659)
Your "About Me" profile says 1978 F150. If you're looking for 460 4WD, you'll have to buy the engine mounting parts aftermarket. Ford didn't offer the 460 with 4WD or a M/T until 1983, and these parts will not work on anything prior to 1980. 1968/78 Passenger Car 460 & 1975/96 Econoline 460 engine mounting parts will not work on any year F100/350. And, 1973/79 4WD's do not use perches, because there is no engine crossmember to bolt them to. The engine supports bolt to the inner frame rails. 1973/79 F100/350 460 2WD: D3TZ-6028-A Right & D3TZ-6029-A Left .. Engine Supports aka perches, stands, towers. D3TZ-6030-A Right & D3TZ-6031-A Left .. Brackets-These bolt to the block, the rubber insulators bolt to these, then to the supports. 2) D3TZ-6038-A .. Right/Left Rubber Insulators. |
(Post 12062659)
"ALL FORD" SALVAGE YARD DOWNSIZING |
1978 F 150 Custom 2wd doing a swap to a 460.Has a 300 in it now. I was told I need to get different Perches.
Thanks |
