STC
What does STC stand for and where is it located. :-huh
STC=Snap To Connect
Its a Fitting that attaches the HPOP to the HPO Standpipes Its on the HPOP they crack and leak usually cause a no start on the 05+ HPOP ACRONYMS FORD https://www.ford-trucks.com/forums/821641-acronyms.html |
ok so I would have to pull my HPOP to see them?
You have to pull the pump to change the fitting but you can see it with the HPOP cover removed. The '03's and early '04's don't have one.
Updated fitting installed on the HPOP. https://www.ford-trucks.com/forums/p...ctureid=101801 STC kit from Ford: https://www.ford-trucks.com/forums/p...ctureid=101800 Here is a good video on the procedure: http://www.youtube.com/watch?v=UuTKD...e_gdata_player |
Originally Posted by BLADE35
(Post 12022198)
STC=Snap To Connect
Thanks for all the info
I just want his torque wrench..... I like the beep.... real handy.... that and it switches between inch-lbs and foot-lbs..... I like....
Originally Posted by berick
(Post 12022953)
Blade & Bismic, thank you for this little link. I have been reading things on here for years and just fumbled by or googled it. I am going to add this to my "6.0 File"!
Funney you mention that I am turning my computer into a 6.0L closer and closer everyday LOL I can only imagine all the info mark has Probably time for me to make a thumb drive copy of all this info I have saved If I had a computer crash I would never recover it all or find some of the info again |
Originally Posted by metmop
(Post 12023629)
