Digital Torque Wrench Special !!
http://www.brownlinemetalworks.com/images/wrench.jpg
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: ft You can see the torque wrench in action in the following video: Brown Line Torque Wrench Product Specifications Patented Double Gear Sensing System Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale) Microprocessor Controlled 8-bit electronics ensures accurate readings and simplicity of use Allows for both Peak and Track mode Individually calibrates each wrench Supplies unique serial number for each wrench Ratchet Head 1/2" drive reversible ratchet 32-tooth gear provides an 11.25º arc while handling high torque loads Forged from Chromium Vanadium alloy to ensure strength Conforms to ASME B107.10 2005 standards Range 15 – 150 ft/lbs 180 – 1,800 in/lbs 20.3 – 203 Nm Digital Control Large backlit digital display shows both target torque and current read-out Intuitive button design makes operating torque wrench simple LEDs and digital display provide visual feedback when operating wrench Buzzer creates audible feedback when target torque is reached Easily switch between ft/lbs, in/lbs, and Nm Automatically powers off when not in use for 2 minutes Low battery indicator Handle Soft-touch overmold provides comfortable non-slip grip Engineered plastics ensure an impact resistant housing The offer is valid until July 21st, and is only for the lower 48 states. |
We have gotten some questions regarding different sizes, and just wanted everyone to know that we currently only have the 1/2" drive version. We are working on other sizes, and they should be available next year.
BLMW |
In order to clarify, you want to select the wrench with case version ($150 retail) on our website, and then enter the FT code in order to get the $99 price.
BLMW |
Very nice!
Do you have a version with a higher rating than 150ft lbs? One that goes to 200ft lbs would be nice, since the lug nut torque on my Ex is 160ft lbs. Stewart |
In answer to some questions, our repair/calibration facility is located in Chicago.
BLMW |
Do you guys calibrate other companys torque wrenches also or just your own and if so what does it cost?
Originally Posted by blmw
(Post 12041474)
BLMW |
In case you are interested, someone just posted a review on You Tube:
Brownline Torque Wrench Review - YouTube |
Only 9 days left. Don't miss out.
Originally Posted by Stewart_H
(Post 12035043)
Very nice!
Do you have a version with a higher rating than 150ft lbs? One that goes to 200ft lbs would be nice, since the lug nut torque on my Ex is 160ft lbs. Stewart BLMW |
Originally Posted by robbragiel
(Post 12042021)
BLMW |
Originally Posted by BadDogKuzz
(Post 12042055)
Where in Chicago is it? And do you calibrate all brand of t.w. I ask because I have a few t.w. I would like calibrated and I live in Gary,IN.
BLMW |
There is only 4 days remaining. Get yourself a great torque wrench.
Got two phone calls the past two days, so I figured I would just post the info:
it runs on 3 "AA" batteries. BLMW |
We have gotten a number of requests, so we are going to extend this special until 8/1. Thanks for the support.
BLMW |
