Lowering my 78' F150 and Crown Vic and DOHC 4.6 w/ manual swap
55 Attachment(s)
Well owned my truck for going on 14 years now. Have done alot of work to it including swaping in a 87' Fuel injected 300 six. Now that I own my 96' dually for towing the race car around I figured it would be kind of fun to lower this one. I have already installed the DJM rear lowering kit and am in the process if doing a Crown Vic from suspension swap. At this point I have removed the twin i-beam suspension and need to start drilling out rivets to remove the front crossmember. Anyway, figured I would share a few pictures as I progress.
Attachment 236288Attachment 236289 Attachment 236290Attachment 236291 Attachment 236292Attachment 236293 Attachment 236294Attachment 236295 Attachment 236296Attachment 236297 Attachment 236298Attachment 236299 Attachment 236300Attachment 236301 Attachment 236302Attachment 236303 Attachment 236304Attachment 236305 Attachment 236306Attachment 236307 Attachment 236308Attachment 236309 Attachment 236310 EDIT....fought the old crossmember and suspension points last night. Alot of Rivet drilling/chiseling/beating/sawzalling/grinding to get everything out but got most of it. Something that seems to be an issue with our year truck that I haven't seen mentioned is that the crossmember is welded in. Still a bunch of work to go but could not resist setting the CV cross member in place. Also I have a lot more structure to fix than just boxing in the frame. Found alot of metal loss under the spring buckets. Attachment 236311Attachment 236312 Attachment 236313Attachment 236314 Attachment 236315Attachment 236316 Attachment 236317Attachment 236318 Attachment 236319Attachment 236320 UPDATE 7/15 Finally got a chance to get back at it. Man these remaining parts of the crossmember are a PITA to get out. Lots of grinding and creative sawzall use. Attachment 236321Attachment 236322 Got a bit more done today...got the rest of the scrap metal out and started to locate the front cradle. Also had to try out some 18" rims I had lying around. Attachment 236323Attachment 236324 Attachment 236325Attachment 236326 Attachment 236327Attachment 236328 Attachment 236329 UPDATE 7/17/2012 Not much progress tonight, just got all the bolt holes drilled and just waiting on my spacers to get cut and I can start welding. Crappy part is I am out of town now for the next 2 days :-(. Guess it will have to wait till the weekend. Hard part is going to be engine mounts. Not looking forward to that. Attachment 236330 Attachment 236331 Attachment 236332 Also placed order for parts to connect steering and brakes Got the sleeves for the bolts today and will be heading back out to start welding things up a little. I am going to weld a nut to the top of my sleeves so the setup will work like the stock CV mounts. Attachment 236333 Attachment 236334 No more c-clamps holding it together the sleeves have been welded and it's mounted to the truck, Have to figure out the rear trailing arm mounts and abox the frame in so not even close to being done yet. Attachment 236335 Attachment 236336 http://img.photobucket.com/albums/v492/wilddm/006-3.jpg http://img.photobucket.com/albums/v4...ddm/001-12.jpg Attachment 236337 Attachment 236338 Attachment 236339 7/21/12 Worked on the Steering linkage a bit, Ended up having to cut the rag joint flange in half to remove it from the column. turns out it is swedged on and after I cut the flange off and the swedged part of the column my 36 spline 3/4" u-joint slid right on. Attachment 236340 Attachment 236341 Attachment 236342 |
Don.t stop there! You can't leave us hanging like that!
What he ^^^ said!!!!!
C'mon. Where's the "money shot"???
This is as far as I am right now. Going out to work on removing the stock cross member this afternoon. I am dreading drilling out rivets, ugh.
Did this with my 69 but i did spring under in the rear.
Thats a beautiful truck. What size tires are those? And whats your paint code or whatever? I love the color and have been wanting to paint mine.
235/75/15's, I don't know the exact paint code it is a 99' GM color Dark Indigo Metallic.
A quick Search on google came up with this.....Indigo Metallic Clearcoat 39/WA9792 |
wow...those are the same as mine. Look so much better on yours though. Must be the lowered factor. Everything looks proportionally perfect in the rear. Cant wait to see the front.
Thanks so much for the code. It truly is a beautiful color. |
Added pictures from last nights progress
its really that easy? Cant wait to see what you do with the motor mounts.
subscribing
Looks good, I am around the same point with mine. Keep up the good work and the pics.
Just added 2 pics, nothing special, working on getting the welded parts of the crossmember out and it sucks, haha. I drilled a large hole in the frame to get rid of some rotted metal and will fill that later.
I saw a magazine article about a plasma cutter with a "chisel" tip attachment that would be perfect for that. now if only we could all afford plasma cutters.
