F250 tailgate
Anyone know how much would it cost to replace a tailgate on a 2009 KR. Mine was stolen this week. The tailgate had the backup camera.
Check CraigsList. Here's at least one I found in Houston.
Ford F250 superduty tailgate Where in Houston are you? Just so I know where to be more careful...just in case. |
Originally Posted by edjunior
(Post 11987894)
Ford F250 superduty tailgate Where in Houston are you? Just so I know where to be more careful...just in case. You could try www.car-part.com to see if any junkyards in your area have them, I found one near me for $600. Then also figure on having it painted unless you are lucky and find one that's the same color as your truck. Assuming you have full coverage, how much is your deductible? Might be better off just making a claim |
How much would it cost to have lock rekeyed to match ignition?
When you put it back
You can do like I did.I assume the newer ones still slip in like the older ones. I have a 99SD
It's a liitle bit more of a PIA to put it in but I removed the hinge took the plastic cup and turned it around so the slot was blocked. Bolted the hinge and tailgate in together so it can't be lifted out. I never could understand why they made them so easy to remove. For added support I used a hose clamp around the hinge tightned from under the truck. Now it takes removing the hinge to removethe tailgate. |
I opted for this on mine:
Amazon.com: McGard 76029 Tailgate Lock: Automotive keeps the honest people out and makes it a bit harder on the crooks ! |
Does anyone know if you can add a factory camera to a tailgate that did not come with that option from the factory. Reason is I found a tailgate for sale that does not have the rear camera option but it's the same color so no painting would have to be done.
I don't know if the cutout is the same or not. I am kinda curious though, isn't your insurance paying for this? I would think they would.
(Post 12004563)
I'm pretty sure it's the same - just swap the handle/camera with the other...
now if you are talking the step and handle - NOT the same tailgate IIRC... |
