Need help! Quality shop?
Looks like head gasket failure is beginning to happen to my 2006 F 350.
I've asked a few shops up this way and I get a very different take from shop to shop. I don't mind spending a little more $$ if the work is exceptional. I'll take her anywhere in Ct. Ma. RI. Just want it right! Any suggestions? Thanks. Todd. |
Deane's auto and truck repair
I have used this shop professionally with an entire fleet and personally with the stuff I didn't want to do. Never had any problems. Very thorough and fast Deane's Auto & Truck Repair, LLC - Tolland, CT Patch |
I think Mass Diesel has a good rep.
You sure its head gaskets not an egr cooler?
What are your symptoms? |
Diesel Shop in preston, ct I think it is
Originally Posted by 7.3 Rocket
(Post 11983847)
What are your symptoms? Ect 205to220 eot 210to225 towing Fan kicks on and the temps tumble down quickly. Deltas are 4 to 8 degrees, even pulling my 5th w. Egr. valve nice and dry. No white smoke or antifreeze smell. Pukes coolant only while towing under load. Found combustion leak when tested. I WISH it was the Egr.! |
Originally Posted by T diesel
(Post 11984906)
Ect 190to195 Eot 196to204 empty
Diesel Shop in Preston, CT, towards MGM Grand at Foxwoods.... Had work done there good group of guys and gal there... Dieselshopct.com
BIG THANKS to m350 on his recommendation! :-X06
Jeremy was fantastic, Truck running AWESOME!! |
