Accurate way to test Coolant/Antifreeze 50/50 mix
Does anyone ever use the Prestone Antifreeze Tester? Or the Peak Tester?
I just flushed my 2005 V10 and looking to make sure that I have a good 50/50 mix. Is there a more accurate way to test it? Thanks ~Gage~ |
Originally Posted by Gage2502
(Post 11975028)
Originally Posted by dusted4eva
(Post 11975291)
I use the Prestone tester. Never had any issues.
http://www.acehardware.com/graphics/...E-997942dt.jpg |
Thanks guys....
Ok so heres what I found with the testers I used the Chaslyn Small Anti-Freeze Tester, & the Prestone one. The Chaslyn I got all 5 balls floting but the fifth one not as high as the others, the Prestone I got a +268 -45 reading on it. Also I need to top it off about a 1/2 gal? was going to mix the Motorcraft Coolant and Distilled water 50/50, but the Motorcraft I have is a open 3/4 full gallon thats about 5 years old, its been in sitting in the truck box all that time is it still good to use? Also I tested it by draining about 1 cup, and by the expansion tank. Thanks ~Gage~ |
(Post 11978505)
Thanks guys....
Thanks Ya I still have a left over new gallon from this flush, but wanted to keep that as a spear. I didnt want two open 1/2 gallons.
Thanks ~Gage~ |
