Ford Truck Enthusiasts Forums
-   Excursion - King of SUVs (http://www.ford-trucks.com/forums/forum29/)
-   -   looking for an Excursion.... (http://www.ford-trucks.com/forums/1168781-looking-for-an-excursion.html)
Nsaan 06-14-2012 01:14 AM
I found one on Craigslist the other day, it is a 2000 Limited 4x4 with the 7.3, it has 176K miles on it now.
I called the owners and it turns out they use the same mechanic I do and looked up the service history on it, the first was in 06' when it had 65K miles on it, shortly after they bought it. I saw that it has had regular oil changes, a power steering pump, the rear end was rebuilt 2 years ago. It has had a billet grill and new lights and front bumper put on it. New rear bumper after someone rear ended it. It has a small dent on the hood where it looks like someone slammed the hood with something under it.
It has new batteries and alternator within the past year. It has a 4 inch lift on it. It also has a Edge Evolution programmer on it right now. AFE intake and 4 inch magnaflow exhaust.
When i was looking at the service history on it I did not find ANY transmission services or rebuilds on it.:-huh
I talked to the owner and he NEVER had any done. 108k miles and NO trans service. I pulled the dipstick and checked it. It was reddish brown but did not smell burnt. That made me feel a little better.
I fired it up, the engine was cold... (as it could be being 100+ outside.) It started easy and i ran around to check the exhaust. It sounded good and strong. No exhaust leaks to be found. No smoke at all at idle. I pulled off the oil cap and checked for blow by, it sat there solid with no movement. No puff at all.:D
Now the fun, the test drive. I checked the A/C works , all the windows work. I drove it down the street and around the corner, got out of the neighborhood and layed into it hard. IT HAULED A$$! I turned onto the main road and floored it, It LIT the tires off the line.:D (guess that is why it needs tires, it has 325/65r18 Nitto all terrains) I stayed in it it hit second and chirped the tires, I let out a bit and it shifted to 3rd and then 4th at just under 90. Shifts were firm and did not slip at all. I drove it back and asked the guy what level the chip was on. He said it was on the highest. (100hp)
It shifted just fine when you were driving it normal. I guess that is good for a trans that has been neglected for that long. I am wondering if the chip is what has kept the trans alive for so long. They have towed with it occasionally like a 25 foot enclosed toyhauler with 2 rhinos in it.
The bad, it needs new tires, Discount wants 1200-1500 for a set...
it needs the drivers seat and arm rest recovered.... it could stand to be detailed, but for a 12 year old family vehicle it is OK.
Now for the question... Would you buy a vehicle that has had the trans not serviced for 6 years and over 108K miles? :-huh:-huh
I am torn on this one. Your thoughts???:-X16
It would be the Family vehicle... the price is good but not good enough that I don't mind taking a chance on the trans going to crap after putting 1200 in tires on it....
Tylus 06-14-2012 03:08 AM
how much they want for it?
look on Craigslist and get a set of take-off tires for cheap
Nsaan 06-14-2012 04:24 AM
http://i1224.photobucket.com/albums/...xpassfront.jpg
http://i1224.photobucket.com/albums/...iondrivers.jpg
a couple shots of it... they want 10K for it...
Nsaan 06-14-2012 04:43 AM
I am going to look at this one next. It has good tires, not lifted, looks like the seat is in good shape and hey it has a trans temp gauge, hopefully that means he serviced it regularly.
2001 Excursion 4x4 7.3l diesel
grishw1 06-14-2012 07:14 AM
Aren't the 7.3 tranny's pretty easy to work on? If I remember correctly my mechanic said they are half of what a 6.0 trans cost to rebuild.
Kdr358 06-14-2012 10:33 AM
10k seems reasonable. When I bought my 2000 ex limited I paid 8200 with just over 271,000 miles on it!
Digger 5 06-14-2012 11:00 AM
$10K is fantastic for my area. I'd buy it as a spare.
Check the power door locks too. That's one thing I didn't check and they were all bad.
Joe28443 06-14-2012 12:10 PM
Don't think that's bad at all. I would jump on it
Gene Horr 06-14-2012 01:12 PM
Even if a transmission rebuild is $3k you are still getting a great deal IMO if everything is as described. Even if it needs an additional $2k in work beyond that you are still at a fair price.
The one thing that would make me hesitate is the tuner. Yes, people use them for legitimate purposes but far too many do it to abuse the engine. I would get a compression test before buying.
SMIGGS 06-15-2012 02:16 AM
I picked my 00 7.3 up for 10K with 185K on it. That is in Canada also.....
jh818 06-15-2012 09:42 AM
'01 diesels could have the mechanical diode in the transmission.
mgraveman 06-15-2012 10:51 AM
I have a customer in AL with a 2001 7.3 with about 110k miles on it. He wants $15k for it and it's in pretty decent shape. I drove it when he was trying to sell it to me, but I can't justify all that extra $$ for just the diesel over my v10.
PM me if you want his #.
Nsaan 08-02-2012 08:59 AM
just a heads up if, I found one and am picking it up this Friday. The new thread is here...http://www.ford-trucks.com/forums/11...excursion.html
First Ford 2004 08-02-2012 10:42 AM
I think this is a great buy.:-X04
