1997 7.3 powerstroke zf5 trans
Its a zf5 trans on a 7.3 poweratroke ok it goes into gear if u keep ur foot in the trottle if no it wines untill u give it gas an while ur gong down the road if u let outa the throttle it comes out of gear stops pulling an wines like alomst a griding noise and it will noy go into reverse unless i put it in 4 low can some one tell me whats causeing this please help!!!!!!!!
I am no manual gearbox expert, but it sounds to me like you need a rebuild. It sounds like you have some bad bearings in the transmission. At least that is my WAG. Someone with more first hand experience will be along shortly I am sure.
Oh, and welcome to the site! |
Thanks i hope i can get some1 who know exacly what it is so i can fix it myself i dont have alot of money to spare an i know these things ant cheap but thanks for the reply
Shift forks are done, and so is your grammar.:-X04 Just kidding around!
As is your punctuation, professor.
I never said if i could read write or spell i jus wanted help with my problem not to be made fun of thanks anywaz
Originally Posted by wilson50
(Post 11951293)
I'm sorry I did not mean to offend, just ribbing you a bit, it was just hard to understand.
Regarding your problem, like I said ealier, that I bet your shift forks are done. This is why it will not stay in gear. The whining can be a gear whine at a lower RPM, if you switched to a single mass fly wheel. If not then I'm sure some one else can chime in who is more educated than I, on trouble shooting a tranny. I have rebuilt a handful of trannys, and for the most part, they are pretty simple to do. The whining can be attributed to synchros on their way out, low fluid level, and so on. Its hard to know exactly what it is untill you get in there and look around. Might be worth pulling and cracking open the case. Its a fairly simple job once you get it out of the truck. If you do rebuild it instead of replacing with another unit then make sure to replace the synchros. You will be happy you did further down the road. Best of luck on the matter and keep us updated with your issues. Just trying to help. :-X22 |
(Post 11951293)
In case you didn't know, it's against internet etiquette to use grammar so poor that it requires effort on the reader's part to understand what you're trying to communicate. That's why any time you make a post like you did in the OP, you will get a couple of jokes directed your way. Don't take it personally, it's just an informal sanction to get you to improve your grammar so that we may more easily understand you. Also, when you're trying to get people to help you, it's usually best to make it as easy for them to help you as possible. I don't really have anything to add about the problem itself, except that I wish you the best of luck and I hope it all works out for you. :-drink |
Welp... Sounds like you are going to have to tear into it soon anyways... It could be something as simple as a throw out bearing gone bad... My zf5 has a few issues going on with it and will need fixed soon... It could be a clutch spring as well I recommend two companys, south bend or valair.
Does the rattlesnake sound happen with just the clutch out, or does it go away when the clutch pedal is pushed in... If it has that grindy sound only when the pedal isn't pushed in its a throwout bearing as for the reverse.... That is very common with these transmissions... Mine will pop out of reverse 4/10 times I back up... I have been pretty annoyed with it, and did some research and found out its pretty common... something you can do, is take the inspection plate off and see if you have a smf or dmf and if so, wiggle it and see if there is any play or looseness going on... |
It on does the wineing noise when ur goin down the road an you let off the trottle if its in 4 low all the gears work fine no problem im thinkin jus secrinizers but idk
(Post 11980999)
It dosent pop out of reverse it wont go in it at all un less its in 4 low.....i havent checked the fluid maybe thats the problem idk i think itsl only has around 130000 on it
Originally Posted by Seven Three
(Post 11980957)
I laughed uncontrollably. Throw out bearing has nothing to do with it falling out of gear. |
Originally Posted by BuckHammer
(Post 11952109)
I mean this in a purely constructive way, and not in a rude or hurtful way:
In case you didn't know, it's against internet etiquette to use grammar so poor that it requires effort on the reader's part to understand what you're trying to communicate. That's why any time you make a post like you did in the OP, you will get a couple of jokes directed your way. Don't take it personally, it's just an informal sanction to get you to improve your grammar so that we may more easily understand you. Also, when you're trying to get people to help you, it's usually best to make it as easy for them to help you as possible. I don't really have anything to add about the problem itself, except that I wish you the best of luck and I hope it all works out for you. :-drink I don't have the education that you appear to have, but I have only been working on it for 70 years. I know many of my posts are not grammatically correct and if it wasn't for spell check I don't think I would be posting at all. I did go back to school at the age of 62 and got a 2yr degree when I was 64, that was extremely difficult being in school with all those young people but I must admit most were very respectful and considerate. Top 10 Netiquette Guidelines for a Safe Online Experience Use Computer Courtesy - Whether a person is sending an email, chatting in a chat room or speaking in a forum, it is important to be courteous and respectful of others online. Always remember the Golden Rule!
For more important Internet Safety information, please read: |
