1978 F-150 Bed Replacement
1978 F-150 SWB 117" 4 wheel drive. The bed is in rough shape and I am looking to replace it. Would a 73-79 f100 bed fit? What year and models would work?
all models from 73-79 work.
Except some from F350's where the frame is a bit narrower.
Originally Posted by Ford F350 Supercab
(Post 11925644)
IIRC All F-250's had a 133" wheelbase (long bed) and all F-350's were all long bed with either a 133" or 140" wheelbase. The OP has a 117" wheelbase which is a short wheelbase truck. |
Thanks that is what I was needing to know. I have found and F100 that has a good donor bed, just wanted to make sure the F100 and F150 would swap they do have the same WB of 117 for a short bed. This is my first ground up rebuild of a F-150.
The f-250 and F-350 has a 133 WB and would not work unless fabbed the bed. |
A short bed is a short bed. No difference.
Agreed with Jon
True about a short bed is a short bed didn't look at it that way till now.
Bigred, if you need any parts I'm parting out 78 f150 4wd swb. Pm me what you need and ill see if I got it. I'm about 1hr south of you in Hayden, AL.
Originally Posted by bigred513
(Post 11925966)
The f-250 and F-350 has a 133 WB and would not work unless fabbed the bed. Short Styleside beds will also be found on F100/350 Super Cabs & F250/350 Crew Cabs. Left quarter panel (bedside): 1973/76 Stylesides have exposed fuel cap(s), while 1977/79 Stylesides have the fuel cap(s) behind doors. |
The regular cabs with an 8 ft bed do have a WB of 133". Mine has the short bed with a wheel base 117"
I have noticed the the open fuel caps vs the ones that are closed. Thanks for the info. |
Hi instead of starting a new thread i just figured i would ask my question here sense it is similar. I have a 1973 F-100 long bed Custom single gas tank will a 1978 f-150 with dual tanks Fit my Truck?
Originally Posted by Custom73
(Post 14092165)
Originally Posted by paredneck33
(Post 14092271)
Yes but you will need to get the correct fuel filler neck for the truck bed. Since Number Dummy already posted the differences in the bed side from 73-76 compared to the 77-79 beds. The filler necks were also changed to match the differences in the bedsides. But yes they will bolt right on. As the mounting points are the same.
Any 1973-79 F100/F150 bed will work but there are a couple of differences. In 1977, the gas fillers had doors put onto them instead of the external screw on caps. Bed will still work but you'll also need the gas filler pipes to match. Secondly, many of the 1978-79s and some '77s had a difference in exterior trim compared to the 1973-76s. New exterior trim to match is expensive.
