1965 Econoline Supervan brake & parking lights not working
I have a 1965 Econoline Supervan and the brake & parking lights stopped working but the turn signals work. I shorted them, l cleaned the socket contacts with steel wool and l didnt see that some had snagged on the socket and when l turned the light switch on they stopped working. Where is the fuse box?
Thanks |
The fuse box is the back side of the light switch.
Fuse box
Lie on your back and look up with a flashlight where the ignition switch is ... you'll see the fuse panel ... or remove instrument panel and look left ... be careful to not blow the panel relay by touching it to the dashboard
thanks, l found it and replaced the blown fuse. I just didnt poke my fat head around enough to find it on my own.
There you go have a 65 Super myself
.J=M |
I think you may want to PM me ... I have a pdf that I am sure you can use
J=M |
