Flat Head ID Help
Hello all.
I am usually hiding in the E-series forums and have owned a few Y-blocks, Windsors and Mods. Now I have an opportunity to pick up some flat heads from an estate sale and I have no idea what they are. Can you help from the pics? https://www.ford-trucks.com/forums/p...ictureid=99768 https://www.ford-trucks.com/forums/p...ictureid=99769 https://www.ford-trucks.com/forums/p...ictureid=99770 Thanks for your help in advance. |
The first one is a 59-AB, second is an 8BA, its got head studs with nuts, if its got pet ***** behind the water pumps its a 48 model, first year in the trucks. Third looks to be a later ohv 4 cyl of some sort.
f5fordgirl, you rock! Thanks.
I am assuming the first two are runners as they are on test stands, sorta. If I can get them for a good price they will make for good project motors. Just need to find the projects now! |
The first engine may not be a 59A (1946-1948) motor. In the picture I cannot see a 59 cast into the bell housing. The radiator it is attached to looks like a 1938-1939 pickup / truck radiator. The generator mount fan is definitely 1939 or older, but the transmission is 1940 or newer. For a definite identification on the first motor look here: http://www.goldengatev8.org/tips/Evo...heFlathead.pdf
Also, DO NOT put the earlier motor on a modern engine stand supported by the bell housing. The 8BA is fine, but I have seen several earlier motors with the bell housing broken off from using incorrect engine stands. |
Thanks for all your help but they all went for too much. The first motor went for $1000! And it would not run, so who know what is inside.
Too much for possible toys. |
Just for curiosity sake, that engine in the bottom pic is for an IH Farmall tractor.......
I just want to say th advice from 38 coupe is exellent, couldnt have said it better.
How do you post pictures, I have a 53 with a flat head in it and would love to find out what model it is or year even. also it has been sitting outside for 10 years(i know) in the truck still but{i still know} what would you do first before starting it as it did run when i originally bought it
