rear drum replacement
This may sound like a dumb question, but how do you remove the drum on the rear of an 86 f250 4x4? I beat it pretty good and cracked it, now it's gotta come off. I'm battling the soft pedal, hardly any brakes syndrome and need to see if I need rear shoes or not. Any other truck with drums would come right off with a couple taps of a hammer
It will depend on the axle, but you may need to remove the axles themselves and then a big nut & bearings inside of there.
If the drums are worn enough to have created a ridge you might have to back off the shoes enough to get them off also.
Originally Posted by ctubutis
(Post 11702328)
I'm assuming it's the d70 rather than the sterling. What's the procedure to get those o axles out? Seems like a lot of Ford engineering to change some freaking brake shoes.... |
Kedwinh is right,you'll have to back off on the brake adjuster to retract the shoes.The drum should then come off like any other.My 10.25 full float sterling was stubborn so I poppd out the rubber from the adjuster access slot,backed the shoes off and the drum slid off.I forget which way I had to turn it,but if it starts to expand the shoes just go back the other way.
Not sure if it will help you but I found it very Informative.
A Boy and his Jeep » Dana 60/70 Rear Drums |
Originally Posted by BRay09
(Post 11703220)
Its a full float rear end, but the drums look different than my 89 and 95.
I'm assuming it's the d70 rather than the sterling. What's the procedure to get those o axles out? Seems like a lot of Ford engineering to change some freaking brake shoes.... It can be a pain to do the first time but once you get it once you'll never have a problem. I would recommend doing everything you want to in there while it's off so you don't have to do it several times. Also have your wheel high so she doesn't leak gear oil out while your in there. Good luck! |
Originally Posted by 81oneton400
(Post 11704258)
Ehh... I'll put the front pads on for now and see how they feel. It's just a mud truck, never sees the road. If it needs it I'll pull it apart. Thanks for all the help, I'll refer back to this if I ever need to do a brake job for someone
Well thats completely different from the full floating 10.25 sterling!I like the simplicity of the sterling but I hate having to readjust the brakes every few months.
Originally Posted by big vann
(Post 11705217)
Full-floating Dana.... Thanks to 81oneton400 for posting that link. :) Pictures are way helpful sometimes. |
Another inormative link for the favorites just in case I decide to do a diff swap.
I put the pads on and got it put all back together and it stops a little better than before. I don't think the rear are doing anything because this stock 351w will spin these big 39's with 4.10 gearseasily when power braked. Looks like ill be tearing into it
It doesn't look too difficult BRay 09.I think that if you follow the procedure in the LINK you'll be fine.
I didn't think it looked difficult, just time consuming and I wanted to get out and play ASAP. But I'll spend the extra cash and do it safely
