Soft brake pedal, firm on second pump. What's wrong?
I have spongy brakes on my '08 EL using about half of pedal travel. The second pump uses about 1/4 travel. My mechanic tried to bleed the brakes of any air but it didn't help. There is no leaking brake fluid. I'd like to get sorted out before heavy towing.
Anyone have an idea if this has to still be air in brake lines, master cylinder seal issue or something else? |
Its been like this for years on ford trucks and expys. Some have it some dont. Search the F150 forums for more info.
You have air in the system somewhere.
Soft brakes
Originally Posted by critterf1
(Post 11649733)
Agree? For the alternate theory that "some of the Expy/F150 just have mushy brakes: I have a hard time believing a 1 million unit per year platform has brakes that cannot be made to work consistently. I hate to say it, but it would seem to me that this is a bad master cylinder seal that doesn't push against the cylinder wall until extra pressure from a first pump pushes it to seal. Does this make sense based on the design of the master cylinder seals (no idea what they really look like)? |
I have the same problem on my '11. Brakes work fine but sometime when you just press the pedal it will almost go to the floor very lightly. Then you press it again and it is rock hard.
Originally Posted by ericjacobsen3
(Post 11630185)
Anyone have an idea if this has to still be air in brake lines, master cylinder seal issue or something else? Now if....you hold your foot on the pedal and with the engine running is slowly drops, then you have a master cylinder issue. |
When you say it takes days to get a bubble out, do you mean the vehicle brakes are open for bleeding? If you mean just wait with the car in service, I have been waiting 8 months and nothing has chnaged.
(Post 12091250)
My mechanic said it was the master cylinder and replaced it for $300. Not a bad price but it didn't fix the problem -arghhh!
Did anyone have this condition on an Expeditionn and successfully fix it with extensive bleeding (that I tried once)? |
I have the same problem on my 07 expy and also had the same problem on my 07 sport trac that I got rid of. the sport trac I bought new and I had it back to the dealer 5 or 6 times they bled the brakes, replaced the front calipers, replaced the booster and master cyl, and did a tsb on the brake pedal, nothing helped. finally at 24k miles the rear brakes were worn down and I was about out of time on the warranty so I traded it in, but I thing that it might be something in the brake bias in the ABS unit. I think that we are stuck with the problem. I just bled the brakes on my expy and i dont think that it helped.
Im not sure if your truck has it but our Navigators breaks are horrible if the pedals are adjusted all the way down. If you have the pedal adjustment than raise them more.
I have been living with this soft pedal issue ever since I bought the Navigator new in 2007. Has anyone come up with a fix or aftermarket solution.
I have no idea why these were designed to be so soft with no easy way to adjust. There is a thread in the F150 forum that shows the brake booster rod being adjusted, solving the issue but apparently the rod has been redesigned. |
My 08 Expy does the same thing...What I believe the problem we are having is in our"Sealed wheel bearing assemblies"...I'm thinking that as the wheel rotates with the brakes not applied,lateral or any excessive runout with the rotor,causes the piston(s) to be pushed in slightly to move the pads away from the rotor surface,then upon the second application,the pads are closer to the rotor(s) surface causing a firmer pedal...If you have ever had a conventional tapered bearing fail or be out of adjustment,you get the same effect....Practically every sealed bearing I've ever "wiggled" on the car has some amount of play...Believe me,this condition can be drastically worsened towing a 27ft travel trailer,(especially in high wind conditions)...just my 2 cents.
That sounds like a good theory. Best I've heard so far.
No wonder the dealer can never really improve the brake pedal feel. It sounds like too much slop in the system resulting from a lack of tight tolerances in design. |
